![]() | Home > General > Have I got an FBH ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
Tried peering down the side of the battery and can't see a thing
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I'm pretty sure that all diesels sold in Europe had it as standard, and the cabin heater was an option; no doubt someone with more knowledge than I have will be along in a mo' Graham
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
I think it was only fitted as standard on diesels of Vogue and above, not the HSE. Discovery 4 HSE
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I've got one!! |
It was fitted to all td6's to overcome the problem of diesel engines running cold for ages on start up. Bit embarrassing for such a prestige car not having a working cabin heater for the first 10+ miles otherwise. |
roverron Member Since: 16 Apr 2009 Location: Londerzeel Posts: 86 ![]() ![]() ![]() |
All FFRR diesel have a FBH, it helps heating up the engine faster so it will give faster heating in the cabin.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35474 ![]() ![]() |
my 2005 HSE has it...i'm sure yours has it joe, unless the previous owner took it out or dis-connected it.. ... - .- -.
ALL diesels have them regardless of spec. Whether it is accesable from the MID is a different story - the fact you have Aux Vent rather than Aux Heating points to the fact it isnt enabled in the SW... |
Mines listed as "Aux Vent" on th obc but operates below 6C on engine startup.
If you turn aux vent on it will just vent.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Joe a few lads on the X5 forums have been doing this. If you don't have the factory screen you can wire up a simple remove system for about £40-50 from maplins. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Plenty of people on the D3 site and some of the RRS lot have been adding extra controls for their FBH's.
Too true ![]() I have the satnav screen, but it only shows Aux Ventilation (don't remember seeing Aux heating) and my screen doesn't look like the one dan_uk put up (although my colour scheme is different) I don't appear to have a remote receiver in the boot, but I didn't look closely (it's hidden under the rear fuse box ?) I'll have to do more investigation, but with the weather like it is and garage full of MG and spare wheels, and dark when I leave in the morning and dark when I get home it'll have to wait til the weekend. Thanks to all for input. Not such a stupid question after all (as I say, "no stupid questions, just stupid people" ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
I'm in the same position as Joe90. Can't see a receiver in the boot and never had a remote.
