![]() | Home > Technical (L322) > Deployable side steps |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Personally I like the deployable side steps. They work fine for me. The post from me above shows that it's just a switch to lock the steps for jacking. My 85 year old mum uses them no problem and she's wheel chair bound. They were also no trouble and well out of the way during the Salisbury Plain off roading recently, although the mud did stick between the step and the sill. Once open they were easy to clean.
Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105 ![]() ![]() ![]() |
Totally agree nomad ! They look great and will have a go when it stops raining over the weekend to get them working |
You are in Manchester - don't expect it will stop raining any time soon |
deplorable (deployable) side steps - that's even better than my transfer s.h.i.t. (shift) motor |
They are deplorable because they are not working ! |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 ![]() ![]() ![]() |
Maybe the fuse is blown or missing and therefore you are getting no joy from the switch? On mine the fuse is the first of the large vertical ones (30A F61) on the far right of the main fuse box behind the glove compartment. I sometimes remove this when the steps are out to absolutely make sure that they don't retract when i jack the car. MY2007 S/C - Stornoway / Jet |
Sorry if forgot to add that you can download the installation manual from LR TOPIX website, although you are not fitting them it does show all the components, where they are on the vehicle, and how they are connected. A good start for any possible fault finding. Try this link it should work hopefully! http://topix.landrover.jlrext.com/topix/co...de%20steps MY2007 S/C - Stornoway / Jet |
Hi J pickie thanks for ur help but can't open that link |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
link is active. |
Scarey thanks for reply but I am not getting anything but the page and nothing else ?m |
If you can't get it to open send me a PM with your email address and I will send you a PDF copy of it. MY2007 S/C - Stornoway / Jet |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
As far as I can tell, Topix only gives access to the really useful stuff to registered trade users. If you are registered I guess the link will work; if you're not it dumps you at the login screen... Graham
I'm not registered and the link i posted works fine on my computer, but not on my Ipad. Why that is i have no idea |
Got 1 side working but not both but still not sure what I did ,will get drivers side off and grease it all to see if it has seized ? |
