Home > Technical (L322) > Deployable side steps
Page 1 of 4 1234>
Glm
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Hi all ,
I am a new member and have just got my 2 nd range ,which is fitted with deployable side steps ! The seller told me that 1 just needed to be taken off and greased as this was a common fault and had turn them off but I can't find out to turn them back on ? Any help please
Post #96868 9th Dec 2011 4:13pm
manual? ... - .- -.
Post #96872 9th Dec 2011 4:14pm
Glm
scarey wrote:
manaul?
There is nothing in the manual ! That was my first point of check
Post #96881 9th Dec 2011 4:20pm
i cant remember reading anything about your problem here so you could try rave which is downloadable from the link in the wiki. ... - .- -.
Post #96884 9th Dec 2011 4:23pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Does Rave cover >2007 Side steps?
Dan posted a link to a >2006 WSM somewhere.
Post #96887 9th Dec 2011 4:26pm
loads off downloads here..
http://www.landroverweb.com/landrover/pdf-land-rover-manuals/
edit ..cant find any ref here... Crying or Very sad ... - .- -.
Post #96888 9th Dec 2011 4:29pm
Glm
Not sure what u mean by rave ? Any help is appreciated
Post #96889 9th Dec 2011 4:30pm
rave is a downloadable workshop manual but i believe it only goes up to 2005 as happy has pointed out....
still looking for you. ... - .- -.
Post #96891 9th Dec 2011 4:37pm
Glm
Cheers so far for your help guys
Post #96892 9th Dec 2011 4:40pm
have a read here..might help
http://www.rangerovers.net/forum/6-range-r...alled.html ... - .- -.
Post #96893 9th Dec 2011 4:42pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I picked up these instructions from somewhere but can't remember where. The bit about turning on is near the end but the rest is vital info:
RR Sidesteps Operation:
To force the steps to stay out regardless of the position of the doors, what LR call 'roof access and jacking mode' get in the vehicle and close the doors, quickly insert the key in the dash and turn to position two, whilst steps still out, then hold the switch for about five seconds until the light in the switch illuminates continuously then remove the key. The steps will now stay out regardless of the position of the doors unless you drive away or lock the vehicle at which point they will return to their normal function.
If the steps are working and you want to disable them: insert the key in the dash in position 1 and hold the switch whilst turning the key to position 2, the light in the switch will flash twice to confirm the system is now off. To turn the system on repeat the procedure but the light will now flash three times to confirm the system is now on. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #96894 9th Dec 2011 4:47pm
mzplcg
The Westminster I borrowed a while back had a switch in the overhead console. Like the interior lights function MANUAL/DOORS/OFF. I switched them off as well, completely useless and banged my ankle more than once 'cos they were too slow deploying.
Post #96895 9th Dec 2011 4:48pm
Glm
Cheers for that! Read it earlier but didn't find the info on them
Post #96896 9th Dec 2011 4:49pm
Glm
Cheers nomad ,I will have a go at that and let you know !
Post #96897 9th Dec 2011 4:51pm
JW911
I think I read on FFRR somewhere that they also need to come off in order to jack the car up. Take them off and get the fixed ones is my advice. 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #96899 9th Dec 2011 5:07pm
Page 1 of 4 1234>
