Home > Technical (L322) > Air suspension inactive |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
it could be the battery...
9th Dec 2011 3:57pm |
1.Go drive it for a few miles then go home.
9th Dec 2011 4:10pm |
re-reading your post , the fitter could have damaged the compressor when he put the spare in, best get a garage to check it out.. ... - .- -.
9th Dec 2011 4:11pm |
starman Member Since: 01 Sep 2011 Location: Stockholm Posts: 82 |
Thanks,
9th Dec 2011 4:13pm |
RRG Member Since: 08 Jan 2010 Location: London Posts: 124 |
When you had your wheels swapped over did you also change the spare wheel?
9th Dec 2011 4:14pm |
thanks scarey. Can i drive the car until then? |
RRG
9th Dec 2011 4:15pm |
No way the suspension was damaged by someone 'jumping' into the car - FFRRs are made of sterner stuff than that!! |
9th Dec 2011 4:16pm |
if you have been driving the range since the garage visit with no problems then i cant see why not, but i would get it checked soon... ... - .- -.
As scary has suggested, go lift the spare wheel out and have a look |
9th Dec 2011 4:17pm |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 |
why dont you check the sensors on the axles, one of them could have snapped (the rubber linkage) hope this helps |
Forgot to mention:
9th Dec 2011 4:18pm |
Dan, i will. But could this be the case, since the spare have not been touched? |
9th Dec 2011 4:20pm |
your post was deleted from general cos you had already posted here ....
9th Dec 2011 4:21pm |
