Home > Technical (L322) > Air suspension inactive
starman
Sweden 2005 Range Rover Vogue 4.4 V8 Giverny Green
(as always, sorry for poor english).
I did search the wiki. No answers.
I searched the web, lots of info, but did not find any perfect answer to my problem.
Here is the situation -
This afternoon i started my 05 FFRR. The warning "air susp. inactive" shows.
i tried the wheel all the way to the right and then all the way to the left. Warning still on.
The light in the centre of the button one use to raise and lower the car lights steady. Not sure it did before?
I pushed that button, nothing happens.
I tried to raise the car. Not working. That other light blinks a few times and then steady at normal mode again.
Around three weeks ago, when i had the wheels changed to winter wheels, the guy doing the job "jumped" in to the rear of the car with one of the summer wheels said "what was that?" It was like the rear end of the car kind of sank a bit when he jumped in.
I haven�t noticed any difference in handling since. Haven�t tried to raise or lower the car since.
I haven�t noticed anything until today.
What can be the matter here?
Guess i need to take it do a shop?
Can i drive it until then?
thanks a lot
Starman
Post #96803 8th Dec 2011 10:22pm
it could be the battery...
you only turn the steering to left/right when a new battery is fitted ... ... - .- -.
Post #96862 9th Dec 2011 3:57pm
dan_uk_1984
1.Go drive it for a few miles then go home.
2.Lock it up and go have a cup of tea. (it is important to lock the car so all the systems go to sleep and reset properly)
3.After 10 minutes go out to the car, unlock it, and start her up - if your problem goes away it was more than likely an electrical glitch caused by a weak battery as already mentioned.
Then report back here ASAP.
Post #96865 9th Dec 2011 4:10pm
re-reading your post , the fitter could have damaged the compressor when he put the spare in, best get a garage to check it out.. ... - .- -.
Post #96866 9th Dec 2011 4:11pm
starman
Thanks,
I tried this morning, but same information.
The battery was changed by the previous owner 5-6 months ago.
Could something have been broken when the "jumped" in to the car w that summerwheel?
I haven�t since that noticed any difference in the ride.
Post #96869 9th Dec 2011 4:13pm
RRG
When you had your wheels swapped over did you also change the spare wheel?
The spare wheel sits over the suspension air compressor and moving the spare in and out can easily dislodge the electrical connections to the air compressor or disturb the air suspension breather that exits into the spare wheel well.
This would be a very simple and quick check before going on to more complex diagnosis
Let us know how you get on
cheers
R
Post #96870 9th Dec 2011 4:14pm
starman
thanks scarey. Can i drive the car until then?
Post #96873 9th Dec 2011 4:14pm
starman
RRG
No the spare have not been changed.
Post #96874 9th Dec 2011 4:15pm
RRG
No way the suspension was damaged by someone 'jumping' into the car - FFRRs are made of sterner stuff than that!!
Post #96875 9th Dec 2011 4:16pm
if you have been driving the range since the garage visit with no problems then i cant see why not, but i would get it checked soon... ... - .- -.
Post #96877 9th Dec 2011 4:16pm
dan_uk_1984
As scary has suggested, go lift the spare wheel out and have a look Thumbs Up
Post #96878 9th Dec 2011 4:17pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
why dont you check the sensors on the axles, one of them could have snapped (the rubber linkage) hope this helps
Post #96879 9th Dec 2011 4:17pm
starman
Forgot to mention:
I�m glad you guys are trying to help me out!
(Too bad my thread was deleted from the general section, where there is more "traffic").
Post #96880 9th Dec 2011 4:18pm
starman
Dan, i will. But could this be the case, since the spare have not been touched?
Post #96882 9th Dec 2011 4:20pm
your post was deleted from general cos you had already posted here ....
i 'started' up your thread here to help you find a solution.. ... - .- -.
Post #96883 9th Dec 2011 4:21pm
