![]() | Home > General > Weatherstrip |
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
Oh and what's the part number for this part? Range Rover SC 35th Anniversary 2006 |
Its not rust as such but corroding aluminium.
Know the part number for these Gaz? Front Driver and Rear Driver? Range Rover SC 35th Anniversary 2006 |
sidmini Member Since: 20 Sep 2010 Location: kent Posts: 45 ![]() ![]() ![]() |
replaced all mine they are just fitted on with pressure. So to remove just lever up using a flat bladed screw driver (coated in tape to avoid damage to paint). I think the parts are around £20-30 per weather guard.
Anybody removed the rear window one as in later model cars? |
Gary i have a 2002 L322 if thats what you mean. The rear door ones also just lever off with a screw drive and the new ones just push on with pressure and make sure you get the width alignment right. |
Sorry I meant the back tailgate Window. The weatherstrip is missing on recent models and I want to take it off but not sure of best method.... |
Ah not done that one yet! i don't think that one just levers up, might slide sideways. Eagerly anyone else who has done this already as water drains into that channel and is a PITA when you lift the tailgate up. |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
Front RH side CGE500700
Thats seems to be a common problem with all weatherstrips mine are fine at the moment but I had this on my 2 year old Discovery 3 . You would think Tata would get their act together and use a bit of Indian rubber or something to get it sorted. Present :2008 TDV8 HSE
Dan, any idea how the tailgate weather-strip is secured? |
I'm sure it's the two side strips on the rear window that holds the bottom strip in place as I noticed I do not have the bottom rear window strip .. ====================================
i think what Mick said, although on microcat it does list 4 fillers i think they are You can paypal direct using - www.paypal.me/duckworthparts
I would suspect a new weather seal will in a few years time corrode again. Would it be possible to strip them back and paint instead of them being covered in a plastic coating |
