Home > General > Weatherstrip
barrieeld
Weatherstrip
I'm looking to replace the black metal trim along the bottom of my Front and Read Driver side windows, is this part called the weather strip? Its not like a rubber but a hard black metal, I want to replace these as they have some small signs of rust bubbling.
Any help would be great. Range Rover SC 35th Anniversary 2006
Post #96595 7th Dec 2011 11:17am
barrieeld
Oh and what's the part number for this part? Range Rover SC 35th Anniversary 2006
Post #96597 7th Dec 2011 11:43am
Its not rust as such but corroding aluminium.
They are available from Dan @ Duckworths and are a very easy fit - look for the screws when door open (Was in a D3 anyway Smile)
Post #96601 7th Dec 2011 12:29pm
barrieeld
Know the part number for these Gaz? Front Driver and Rear Driver? Range Rover SC 35th Anniversary 2006
Post #96604 7th Dec 2011 1:07pm
sidmini
United Kingdom 2002 Range Rover Vogue 4.4 V8 Atacama Sand
replaced all mine they are just fitted on with pressure. So to remove just lever up using a flat bladed screw driver (coated in tape to avoid damage to paint). I think the parts are around £20-30 per weather guard.
shame they corrode and bubble up the plastic, should be made out of something better or coated in rubber themselves to stop corrosion.
Post #96607 7th Dec 2011 1:13pm
Anybody removed the rear window one as in later model cars?
Post #96608 7th Dec 2011 1:17pm
sidmini
Gary i have a 2002 L322 if thats what you mean. The rear door ones also just lever off with a screw drive and the new ones just push on with pressure and make sure you get the width alignment right.
Post #96609 7th Dec 2011 1:20pm
Sorry I meant the back tailgate Window. The weatherstrip is missing on recent models and I want to take it off but not sure of best method....
Post #96610 7th Dec 2011 1:21pm
sidmini
Ah not done that one yet! i don't think that one just levers up, might slide sideways. Eagerly anyone else who has done this already as water drains into that channel and is a PITA when you lift the tailgate up.
Post #96612 7th Dec 2011 1:29pm
duckworthparts
Site Sponsor
Front RH side CGE500700
Rear RH side CGE500720
£26.50+VAT each You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #96613 7th Dec 2011 1:43pm
Googsy
Thats seems to be a common problem with all weatherstrips mine are fine at the moment but I had this on my 2 year old Discovery 3 . You would think Tata would get their act together and use a bit of Indian rubber or something to get it sorted. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #96614 7th Dec 2011 2:06pm
Dan, any idea how the tailgate weather-strip is secured?
Post #96616 7th Dec 2011 2:19pm
I'm sure it's the two side strips on the rear window that holds the bottom strip in place as I noticed I do not have the bottom rear window strip .. ====================================
Post #96624 7th Dec 2011 3:50pm
duckworthparts
Site Sponsor
i think what Mick said, although on microcat it does list 4 fillers i think they are You can paypal direct using - www.paypal.me/duckworthparts
Post #96625 7th Dec 2011 3:53pm
I would suspect a new weather seal will in a few years time corrode again. Would it be possible to strip them back and paint instead of them being covered in a plastic coating
Post #96636 7th Dec 2011 4:32pm
