Home > Technical (L322) > FBH that old chesnut AGAIN!!
Renegade2
Guys i am sorry to bring this one up again as there have been many threads covering the topic, but tis one is really confusing me now.
I have a Range Rover 05 TD6 (with touchscreen) which i bought from new, had little problems touch wood, but the FBH s puzzling me. This morning we had a frost in Cardiff and when i started the car i could here the familiar noise of the FBH working no problems, I have the timed cimate on the Touchscreen and if i set it to start at a certain time works OK, if i try to switch it on manually i get the flashing light above the rotary dial but nothing happens. When i touch the manual button and hold it it has a green outline but when i realse my finger it turns red.
Also i have recently purchased a T91 remote fob which accrding to the Webasto site is backwords compatible to the T80 yet i can not get it to conect with the car, i have tried fuse 59 as suggested but no good.
Anybody have any ideas, i really appreciate the help
Post #96280 5th Dec 2011 10:23am
stu
hi, i had a a mare getting my T91 remotes to work. the T90 paired every time easy!!
can i suggest you start with the remote batteries, something as stupid as this can screw everything. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #96566 6th Dec 2011 10:15pm
dan_uk_1984
After u pulled fuse 59 did u then re-pair the handset?
Post #96567 6th Dec 2011 10:17pm
stu
yes if i remember correctly i did. i think one of my problems all along was that the batteries were very week and not transmitting properly.
i have a pdf copy of the webasto T91 hand book, if you send me an email address i will forward it to you if you like. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #96571 6th Dec 2011 10:26pm
