![]() | Home > Technical (L322) > Pre Heater FBH |
Neil E Member Since: 05 Jan 2010 Location: North West Posts: 60 ![]() ![]() |
Car went in to an Landrover indie for the front drivers heated seat and rear cam fault.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
first thought would be the fuse.. |
I`ll check in the morning. The dashboard light comes on and flashes to say it`s working though. MY21 P400e AB
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Hi i have a simliar problem in that on my 05 MY06 if i set the timer fires up ok, if i try to switch it on manually the light flashes to say it is wroking but it does not fire. I also bought a T91 remote which is according to webasto site compatible but i can not get it to code to the car, tried fuse 59 which is on a few threads here, but no good. |
Checked fuse 59 and it`s ok.
Might not be your issue but if it doesn't start after 2 or 3 attempts then it goes into "safety lockout" and it needs to be reset.
With reference to the lcokout i found this on RAVE
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6415 ![]() ![]() |
Note this bit:
CUE99T I see you have a V8 petrol model so although not impossible it is highly unlikely your car has a pre-heater fitted , it is primarily a function of diesel engined cars due to slow warm up because of the thermal efficiency of modern diesels.
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
On the BMW V8s I think the tell-tale is whether there is an "auxiliary heating" option appears on the main menu as well as an "auxiliary ventilation" option. |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
Took it back to the indie garage and he set the timer and it came on!
just a thought, is everyone who's trying to get their keyfobs to work have a receiver fitted... |
roverron Member Since: 16 Apr 2009 Location: Londerzeel Posts: 86 ![]() ![]() ![]() |
Fact: all FFRR with diesel engine have FBH: it helps heating up the interiour faster when engine is running; the fbh is automaticly activated when outside t° drops below 5 ? °C
