Home > In Car Electronics (L322) > '02 HSE ICE Car PC Project (Carx to XBMC to FFRR-PC!) |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Sorry, please revisit my earlier post - same radio afterall.
5th Dec 2011 9:56pm |
Joe did you consider installing something like an optiplex fx series from dell in the boot instead as the space it would take up would be a near perfect fit, allows 6 USB connections straight into it, wifi, large internal HDD, ability to have external data mounting made up(not eSATA) and is very tweakable and can take 16gb ram and run win 7 quite happily and has one fan just to cool the HDD which isn't needed for normal pc use in my testing of them oh and with the mini pci-x on the board you can stick a 3G module if you wanted or anything that takes your fancy
5th Dec 2011 11:03pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
the green wire is the ground switch wire and goes to pin 17.. when the interface receives the command from carx on start up,the usb interface grounds this wire and it will switch your monitor to av only..this is all it will do, the other part of the interface will carry on watching the ibus commands.
5th Dec 2011 11:13pm |
@kingpleb
5th Dec 2011 11:34pm |
joe.. you need a vga to compersit converter this is what you will connect to your av lead.
5th Dec 2011 11:38pm |
Yes, got it
6th Dec 2011 12:09pm |
is yours a 3v converter... if so you can run it of a usb port .that means it will only work when your lap top is one V8 facelift Range Rover Autobiography 22" wheels.
6th Dec 2011 4:55pm |
Yes daveo - see the USB cable in the picture! Been using it to send video to a second TV from Media Centre at home so should be fine in the car.
6th Dec 2011 6:11pm |
ok joe... you have 4 wires coming of the usb interface
6th Dec 2011 6:58pm |
Aha ! .
6th Dec 2011 9:09pm |
OK, made the other three connections to the iBus interface and did a trial run, connecting up the PC. Didn't go too well
7th Dec 2011 2:08pm |
Bah, just retraced my steps - sent my GREEN wire to pin 17 of the white connector instead of the BLUE connector (Must pay attention in class!) Have to get my soldering iron out again! .
7th Dec 2011 5:27pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
7th Dec 2011 5:44pm |
Thanks for your encouragement scarey
7th Dec 2011 6:11pm |
