Home > Technical (L322) > tv transmitters
tv transmitters
does any one remember the illegal tv transmitters that were available about 10 year ago...they had an audio and video input and would transmit an analogue signal to a selectable frequency..
my thought is if you had one of these in the range connected to a freeview box or dvd you could watch said media via your analogue tuner on your screen..
i've searched ebay but have not found anything ,anyone else know if these units are still available..
Post #95432 1st Dec 2011 8:43am
Deep Down
France 2003 Range Rover Vogue Td6 Adriatic Blue
Something like this - http://www.ebay.co.uk/itm/Wireless-PAL-SEC...548wt_1324
I was looking into this originally. It should work as long as you can change the digi box channels easily.
Post #95435 1st Dec 2011 8:53am
thats the thingy. Thumbs Up
stick that in the back near the ranges antenna and feed from a freeview or dvd from somewhere in the front..
its a tempting alternative to the £300+ digital tuner option..
Post #95437 1st Dec 2011 8:58am
Just do an ebay search on wireless video sender, there are allsorts available. We use one at work to shunt A/V from one end of a large room to the other without cables. works a treat. .
Post #95466 1st Dec 2011 12:03pm
I've got similar in mine. Use a TV in motion cable which has an video input. I had a DVD player attached but have gone for a freeview tunner now. While stationary its good but on the move it's pretty useless. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #95488 1st Dec 2011 1:05pm
@joe, is that not the ones with an a/v input on the transmitter and an a/v output on the receiving end, if so they wont work..
@rob, good option but the 'video in motion' kits are for pre touch screen ranges so no good for me. ..
Post #95490 1st Dec 2011 1:12pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Don't know if the quailty will be adequate, but it may be possible to transmit on the security camera frequency and watch on the venture cam input.
Gone - Range Rover Supercharged 2006
Post #95492 1st Dec 2011 1:15pm
good thought justin , but i dont have a venture cam so i assume my screen wont be activated..
Post #95493 1st Dec 2011 1:18pm
Ah right, you want to pick up the signal with the antenna not transfer signal from front to back. My apologies Big Cry .
Post #95547 1st Dec 2011 4:00pm
back into the spinning thingy you go... Laughing
Post #95554 1st Dec 2011 4:29pm
