Home > Technical (L322) > Ignition Supply
broncoupe
Ignition Supply
Re 11 spec Full size TDV8
Does anyone know where in the rear fuse box i can pick up a proper switched 12 volt feed
Most of the fuses are permanently live or if switched they remain power on for about 30 seconds.
Your then hear an audible click and they turn off,
I was wondering if the fuse box uses a can signal for turn on?
thanks broncoupe
Post #95149 29th Nov 2011 7:11pm
The tow socket (s) supplies will have at least 1 (possibly 2) ignition circuits which could probably be used.
Post #95163 29th Nov 2011 8:29pm
broncoupe
Where are they located please
Post #95173 29th Nov 2011 8:56pm
No idea I'm afraid, I only have a TD6, but they will be there.
Will be listed in the fuse schedule?
A 12S socket has 2 switched +ve's for fridge and battery charging.
The 13 pin only has the fridge supply.
If you can't get onto the fuses you should be able to pick up off a cable and install an in-line fuse.
Post #95182 29th Nov 2011 9:07pm
