Home > Maintenance & Mods (L322) > Front Right Wheel 'Squeak' |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
Wheel squeaks normally eminate from a stone stuck inbetween the caliper and disc, sometimes impossible to see it if it's small and wedged inside the caliper near the discs, only taking the pads out will ensure there is nothing there.
28th Nov 2011 11:24am |
Warped Disc? |
28th Nov 2011 11:27am |
Does it happen under braking in a straight line? Discovery 4 HSE
28th Nov 2011 12:41pm |
JIMMYM Member Since: 06 May 2010 Location: Saddleworth Posts: 29 |
Could be one of many things - power steering rack or pump, belt on power pump or one of various balljoints on front wheel.
28th Nov 2011 12:51pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I recently got rid of a seriously annoying slow speed squeak when turning by putting loads of copper slip all over the back of the pads.. Silence.. Previously..
28th Nov 2011 4:37pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Try the ball joints on the lower front arms. I've pierced a hole in mine before now and sprayed silicone spray in them and they shut up immediately then put a small blob of sealant over the hole...
28th Nov 2011 11:22pm |
mnemonick Member Since: 24 Oct 2011 Location: Yorkshire Posts: 5 |
Thanks for all the advice guys - much appreciated! I'll try some of the above and report back...
29th Nov 2011 8:57am |
