Home > Maintenance & Mods (L322) > Mirror approach lamps - led bulbs |
have a read through this … might help
20th Nov 2011 2:10pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
yep found this, did mention it in a post a while ago, you need to put a small resistor with the same value on both sides, it then falls the system into thinking the normal bulbs are still fitted. V8 facelift Range Rover Autobiography 22" wheels.
20th Nov 2011 2:49pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Or, you might have both of them in the wrong way round. LEDs are directional. I replaced loads of filament bulbs on my D3 with LEDs, no issue at all. The indicators DO need resistors though. Graham
20th Nov 2011 4:18pm |
Blackbird51 Member Since: 22 Sep 2011 Location: Portadown Posts: 39 |
Cheers for fast responses LEDs are fitted correctly. Reckon it must be the resistor issue. Now to find some suitable led bulbs. Will post result. |
20th Nov 2011 4:44pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
its the same with the map reading lights, normal leds dont work.. |
20th Nov 2011 6:35pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
This would explain that problem then!
20th Nov 2011 8:05pm |
Tried 4smd LEDs with built in resistor. Things are improving but only just!! Both LEDs illuminate but only for 2-3 seconds. No fade. Does anyone know the resistance required to get correct operation? |
22nd Nov 2011 7:13pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
Seems to be an awful lot of effort just to put some LEDs in. I'd have thought you're better off with normal bulbs, as LEDs are all pretty directional and you want the light to spread out a bit more for the approach light to function suitably. |
22nd Nov 2011 7:25pm |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 |
Are these LED bulbs not illegal for use on the outside of a car? |
15th Dec 2011 5:12pm |
leds are ok to use..
15th Dec 2011 6:05pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
When I changed all my interior lights for LED lights I cut and soldered the live wire to the mirror puddle lamps into the lower door panel illumination circuit, so they work without the fault and a bonus is, they stay on with the interior lights for longer!
15th Dec 2011 10:45pm |
edit on my previous post..
16th Dec 2011 8:18am |
