Home > Technical (L322) > FLAT BATTERY RR |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
FSR?
18th Nov 2011 8:44pm |
Double post |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
To check for leakage buy yourself one of these
18th Nov 2011 9:14pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
How old is the battery?
18th Nov 2011 9:43pm |
blench99 Member Since: 18 Nov 2011 Location: northumberland Posts: 24 |
thanks for the quick replies, first of all i've done a check with amp meter & removed each fuse to see if there is a drain but found nothing.Not sure how old battery is, battery goes flat overnight but sometimes can go flat when parked up after travelling 20 miles, all locations . Never tried disconnecting battery overnight yet but will try it this weekend. many thanks |
18th Nov 2011 10:05pm |
sorry i forgot , no other mods with electrics. |
18th Nov 2011 10:06pm |
Really sounds like duff battery, and given it has gone flat several times it won't be in peak condition any more. But worth checking out the alternator before stumping up the (@) £110 for a new battery.
18th Nov 2011 10:33pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Had the same with mine as soon as it became colder last year. I had the battery replaced by an LR specialist who were very surprised to see the car had it's original battery ('05 car).
18th Nov 2011 11:04pm |
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 |
its sounds like your battery has a floating cell, theres nothing on the car that can drain a good battery in 20mins. |
18th Nov 2011 11:18pm |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
had similar. Check what alternator is producing on and off load but my advice would be to change the battery (100Amp min) - LR put a warranty battery in a week after ownership and it never was very good - flat battery every two months or so. Paid for a Bosch one from Costco - she has not missed a beat since. Lock the car overnight too - shuts every module down properly - consider also a battery conditioner - Lidl do a good one every now and then for not much!
19th Nov 2011 1:46pm |
New Battery..... |
19th Nov 2011 2:43pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
I reckon it's a dud battery too. However it could be a faulty alternator.
19th Nov 2011 3:20pm |
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 |
1. What was the drain amp draw when you tested it? 2. Check alternator is charging correctly (13.5v - 14.5v) electrics on. Ie heater, lights, stereo ect and rev to 2000rpm. Range rover td6 54 reg touch screen |
23rd Nov 2011 8:58pm |
not sure what the drain was, alternator charging ok. i put new battery on on tuesday and so far so good. thanks |
23rd Nov 2011 9:51pm |
