Home > Technical (L322) > HEATING PROBLEM WITH NO CURE
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Hi to all.Unfo trying to solve heating problems in my TD6 long time now but still nothing and worse is that cannot be found what is going wrong.Problem stands as follows:
Heating is properly working as long as the car is running upto 3000rpm.By the time exceeding this nr of rpm the warm/hot air stops and instead cold air is coming out of the ventilators.
-RR workshop can find nothing as whenever they plugged car the computer has shown not any malfuctions.
As a precaution they have checked the flaps motors which are normally working.
Also changed both temperature and air quality sensors but not any result. Big Cry
Any ideas what to look for??????
Post #91042 8th Nov 2011 5:39pm
check your coolant level and the coolant temp sensor... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #91043 8th Nov 2011 5:45pm
AKIS
Scarey thanks for your suggestion.Have checked coolant/sensor and seems to be ok. Banging Head
Post #92651 16th Nov 2011 4:07pm
i dont think you would go over 3000rpm on a normal run, but its worth finding out the reason why though.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #92656 16th Nov 2011 4:32pm
Do the TD6's have a blend motor? Could this be the issue? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #92739 16th Nov 2011 10:26pm
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
Sounds like it could be a sticky thermostat.
Not closing and therefore all OK whilst engines revving. Loses warmth at low revs. Poss accompanied by using more diesel than usual Thumbs Up 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #92771 16th Nov 2011 11:58pm
OP has problem over 3000 rpm ray... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #92788 17th Nov 2011 9:06am
rayc
Ha! Embarassed
That's what happens trying to read it on the iphone without me glasses on! Embarassed
Water pump? Whistle 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
plus a few more!
Post #92800 17th Nov 2011 9:24am
fisha
Does it do this even when you have the temp set all the way to 28°C ( Max )
From the RAVE manual:
Quote:
Temperature Control
To determine the amount of heat required, in the form of coolant flow through the heater, the ATC ECU compares the
reference value with the heater matrix temperature and incorporates a correction factor to compensate for changes
of coolant flow rate with engine speed. From the resultant value the ATC ECU determines the open duration of the
coolant valve and outputs the appropriate control signal. On the high line system, separate values and output signals
are generated for each coolant valve to produce the individual temperature control for the LH and RH sides of the
passenger compartment.
When the temperature setting on the control panel is set to maximum, the ATC ECU signals the coolant valve to
remain open. When the temperature setting on the control panel is set to minimum, the ATC ECU signals the coolant
valve to remain closed.
On the high line system, the minimum setting is over-ridden when the defrost programme, maximum A/C, rest heating
or FBH functions are selected.
The hot coolant that reaches the heater matrix is controlled by a valve limiting how much hot coolant actually gets into the heater matrix. It also seems to vary on engine speed. I assume that the higher the engine speed, the more it closes down the valve.
I've known mine to be a bit irregular on occasion due the wiring on the connector to the valve needing a little wiggle to re-seat it. As you stand at the front of the engine bay, the valves are bolted to the right hand side section of the engine bay that holds the suspension strut. On a UK car, it would be down below the ABS unit. You should be able to see the coolant pipes run forward to it and back from it again. Its may be worth checking the connector on the valves. I think cause they are so close to the engine ( on a V8 they are anyway ) the heat can degrade them a bit .
( thinking about it it more... )
I wonder if you have a slightly poor connection ... and that its only opening the valve up half as much as it should do ... if the engine speed increases, the valve gets closed down, but cause you're already half closed to a poor connection, the valve is almost completely shutting off .
Beyond that, you really need to see the readings on a diagnosis computer to see that the system is doing at the rev ranges. V8 or else ...
Post #92843 17th Nov 2011 11:43am
AKIS
Yes even by setting temp to max is doing the same and by the way even when warm air is getting out of vents,at low rpm,temp is not stable,u can easily feel the temp variations higher/lower but atleast is not getting completely cold as when u increasing rpm.
Post #93586 21st Nov 2011 5:11pm
AKIS
Hi to all and back to subject again.Checked valves/connections all ok.I have also changed coolant temp sensor just for being on safe side.Unfo nothing has changed.Still same symptoms/there is hot in only whever car decide to do so. Banging Head
Post #96258 5th Dec 2011 9:56am
fisha
what about the temp sensor in the cabin itself ... I wonder if its a bit duff. If it doesn't think it needs heat in the cabin, it wont open up the valves.
Maybe a wee hoover of the grill area on the centre console to clear it out? A bit random, but hey, any port in a storm ! V8 or else ...
Post #96285 5th Dec 2011 11:52am
AKIS
Fisha,
Tks for spending some time trying to assist.Just to put u completely in picture
Whenever car is plugged not any damage of malfunction is shown
-Internal temp and air quality sensors hv been changed.
-Coolant valves checked and ok
-Flap motors checked and ok
-Coolant temp sensor changed
Unfo seems that i hv already entered in an endless story Big Cry
Post #96325 5th Dec 2011 4:22pm
Could your coolant pump be slowing at high engine speed due to drive belt slippage or even the drive pulley on the coolant pump slipping on the shaft?
Post #96326 5th Dec 2011 4:33pm
Diver Bryn
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Re: HEATING PROBLEM WITH NO CURE
Also changed both temperature and air quality sensors but not any result. :blub:
I also have a problem with my heater system in my TD6 2005 Vogue. I have just drained the coolant and topped off and had it bled properly (Heater open and bled three valves after engine hot at Temp 1200hrs) hot air comes out at 50% normal heat, but If I press Feet / Windscreen the tempeture is cold??? Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Renault Fuego 2 ltr TX
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Volvo 740 TDi Estate
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Land Rover Discovery 3 TDV6
Mini Cooper Diesel
Mercedes Vito Van 111
Range Rover TD6
VW Golf 2ltr GTD 2015 Year
2016 Audi Q7 Sline 3ltr 272Bhp
Post #101947 16th Jan 2012 4:21pm
