Home > Technical (L322) > HEATING PROBLEM WITH NO CURE |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
check your coolant level and the coolant temp sensor... ... - .- -.
8th Nov 2011 5:45pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Scarey thanks for your suggestion.Have checked coolant/sensor and seems to be ok. |
16th Nov 2011 4:07pm |
i dont think you would go over 3000rpm on a normal run, but its worth finding out the reason why though.. ... - .- -.
16th Nov 2011 4:32pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Do the TD6's have a blend motor? Could this be the issue? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
16th Nov 2011 10:26pm |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 |
Sounds like it could be a sticky thermostat.
16th Nov 2011 11:58pm |
OP has problem over 3000 rpm ray... ... - .- -.
17th Nov 2011 9:06am |
Ha!
17th Nov 2011 9:24am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1305 |
Does it do this even when you have the temp set all the way to 28°C ( Max )
The hot coolant that reaches the heater matrix is controlled by a valve limiting how much hot coolant actually gets into the heater matrix. It also seems to vary on engine speed. I assume that the higher the engine speed, the more it closes down the valve. I've known mine to be a bit irregular on occasion due the wiring on the connector to the valve needing a little wiggle to re-seat it. As you stand at the front of the engine bay, the valves are bolted to the right hand side section of the engine bay that holds the suspension strut. On a UK car, it would be down below the ABS unit. You should be able to see the coolant pipes run forward to it and back from it again. Its may be worth checking the connector on the valves. I think cause they are so close to the engine ( on a V8 they are anyway ) the heat can degrade them a bit . ( thinking about it it more... ) I wonder if you have a slightly poor connection ... and that its only opening the valve up half as much as it should do ... if the engine speed increases, the valve gets closed down, but cause you're already half closed to a poor connection, the valve is almost completely shutting off . Beyond that, you really need to see the readings on a diagnosis computer to see that the system is doing at the rev ranges. V8 or else ... |
17th Nov 2011 11:43am |
Yes even by setting temp to max is doing the same and by the way even when warm air is getting out of vents,at low rpm,temp is not stable,u can easily feel the temp variations higher/lower but atleast is not getting completely cold as when u increasing rpm. |
21st Nov 2011 5:11pm |
Hi to all and back to subject again.Checked valves/connections all ok.I have also changed coolant temp sensor just for being on safe side.Unfo nothing has changed.Still same symptoms/there is hot in only whever car decide to do so. |
5th Dec 2011 9:56am |
what about the temp sensor in the cabin itself ... I wonder if its a bit duff. If it doesn't think it needs heat in the cabin, it wont open up the valves.
5th Dec 2011 11:52am |
Fisha,
5th Dec 2011 4:22pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
Could your coolant pump be slowing at high engine speed due to drive belt slippage or even the drive pulley on the coolant pump slipping on the shaft? |
5th Dec 2011 4:33pm |
Diver Bryn Member Since: 16 Jan 2012 Location: Durham Posts: 34 |
I also have a problem with my heater system in my TD6 2005 Vogue. I have just drained the coolant and topped off and had it bled properly (Heater open and bled three valves after engine hot at Temp 1200hrs) hot air comes out at 50% normal heat, but If I press Feet / Windscreen the tempeture is cold??? Diver Bryn Previous Transport: Honda CB250n Toyota Starlet Renault Fuego 2 ltr TX Fuego Turbo BMW 528i Escort RS Turbo Capri 2.0 L Ghia Kawasaki GT750 P4 Mini Metro Ford XR2 Volvo 740 TDi Estate Mondeo Tdi Volvo V70 Tdi Mercedes E300 TDI Mercedes E320 Cdi Mercedes S320 Cdi Land Rover Discovery 3 TDV6 Mini Cooper Diesel Mercedes Vito Van 111 Range Rover TD6 VW Golf 2ltr GTD 2015 Year 2016 Audi Q7 Sline 3ltr 272Bhp |
16th Jan 2012 4:21pm |
