Home > In Car Electronics (L322) > Aux input
supershuttle
Aux input
On my 2007 there is an Aux input on the back of the centre consol.
So, as the cheapskate I am I bought a splitter cable (phone to line out/charge) off eBay for less than 3 quid to provide low cost iPhone integration for the music whilst charging through the one cable, the rest is handled by a Wiggs modded BT module.
Imagine my dissapointment (but not surprise) to find that the Aux socket is only delivering a signal to the RHS. I have confirmed beyond any reasonable doubt Your Honours that the cable is not guilty. Therefore before I start hacking about I thought I should ask if anyone got experience of this, until now, undiscovered problem with my car.
After all asking on here stopped me taking a chisel to my wheel nuts Very Happy Geoff
Post #92383 15th Nov 2011 3:06pm
The AUX input is probably only a stereo three point connector (Left/Right and Ground) with no power. Does a "normal" stereo lead from your phone / other device deliver both channels OK? .
Post #92432 15th Nov 2011 5:43pm
supershuttle
You're right the aux input is a 3 ring mini jack plug the lead splits from the iphone one part going here and the other to the USB charger. But it's definitely the aux input that's the problem, nothing gets sounds to the left channel. Geoff
Post #92434 15th Nov 2011 5:47pm
I use the AUX method to listen to my iPhone and all is well. I assume you're using the 3.5mm jack?
I use a separate cable (fed from the ciggy lighter in the centre console) to charge. Got - 2017 SDV8 Autobiography in Loire Blue
Post #92435 15th Nov 2011 5:47pm
supershuttle
that's right the aux socket is simply not delivering the signal to the left channel of the amp - screwdriver out methinks Very Happy Geoff
Post #92439 15th Nov 2011 5:52pm
simon1233
Geoff - if you want to try another cable before getting into the trim panels give me a shout, I have a couple that work and can only be a couple of miles from you at the most Thumbs Up
Simon
Post #92502 15th Nov 2011 7:31pm
