Home > Wheels & Tyres > Wheel nuts for different alloys Guide
Page 1 of 4 1234>
feldo1979
United Kingdom 2003 Range Rover Vogue Td6 Giverny Green
HI just found the site,best one out there.
just a quickie,
I have some standard alloys on my RR. 18" i think?
anyway Ive got my eye on some 20" 7 spoke oem from a 2008 tdv8?
will they fit straight on?
thanks in advance
craig
Post #9231 10th Dec 2009 8:58pm
ENVOY
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Im no expert but i would imagine that they would fit straight on , mine is an 03 TD6 WITH 20'S and they wernt fitted as standard!
Post #9233 10th Dec 2009 9:13pm
itguy
2006 Range Rover Vogue Td6 Cairns Blue
BE CAREFUL!
They will fit on the hubs but you'll need new wheel nuts.
The nuts you have will fit but are too loose on the post MY06 wheels. You probably have black wheel nuts now, and you need silver ones.
I've seen a pic showing the two types side by side before somewhere, will hunt it out
Post #9235 10th Dec 2009 9:23pm
itguy
Right - this should become a sticky as I've seen this asked more than once in a few days!
Here is the pic
LR Tech Bulletin in July 05 said
"Situation: Alloy wheel and wheel nuts have changed configuration on the 2006 Range Rover models to a style similar to that used on the LR3. The change means that compatibility of Range Rover alloy wheels and lug nuts is linked to model years.
The 2006MY Range Rover alloy wheels have a modified wheel nut seat with a tapered angle. The new wheels are installed using wheel nuts of the same type used on LR3 and also Range Rover Sport. These wheel nuts are not compatible with the wheels fitted to 2003-2005 MY Range Rover vehicles.
Action: Wheels and wheel nuts (KIT or standard equipment) used on 2003 2005 MY Range Rovers must not be used on 2006 MY vehicles. Locking wheel nut kits are now model year specific and must match the wheels being installed. Model Year 2006 locking wheel nut kits will be announced shortly."
Post #9236 10th Dec 2009 9:32pm
feldo1979
thank you very much for the reply's.
So in a nutshell all i need is some RRS wheel nuts?
Post #9286 11th Dec 2009 7:41pm
itguy
if your car is pre 2006 yes, I believe so FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9287 11th Dec 2009 7:48pm
feldo1979
thank you very much it guy,
i just need to find some nuts now.
EBAY here i come Razz
Post #9292 11th Dec 2009 9:07pm
itguy
prepare yourself - they're not cheap!
Remember new locking nuts and adaptor too FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9298 11th Dec 2009 9:36pm
daveo
hi all, was following this thread, i have the 22 overfinch tigers on my 04 FFRR and have the black nuts,got confused with the later wheels and nuts,do i have to swap to the taper nuts..
daveo
Post #9302 11th Dec 2009 9:56pm
feldo1979
Theirs some oem on eBay at the mo for 40 quid for twenty,
locking nuts i haven't looked yet,
and the word adapter? is that the collar to take the locking nuts off?
Post #9303 11th Dec 2009 10:00pm
itguy
yep - I mean the locking wheel nut adaptor.
Obviously you only need locking wheel nuts if you want them - but I would... FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9305 11th Dec 2009 10:11pm
itguy
I've just re-read your first post. Are you sure the 7 Spoke TDV8 wheels are the ones that were supplied with that car or are they some pre 06 ones that they've fitted to it?
Easiest way to tell for sure is to get the seller to measure the diameter of the wheel bolt hole - post it up here and I'll measure one of my >MY06 bolts FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9306 11th Dec 2009 10:13pm
feldo1979
here is the link mate hope it helps
http://cgi.ebay.co.uk/RANGE-ROVER-ALLOY-WH...4a9cd6febc
Post #9311 11th Dec 2009 10:41pm
itguy
they look like the post 06 ones to me - they've got dimples in between the bolt holes, where as my pre 06 ones have holes instead of dimples. FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9312 11th Dec 2009 10:52pm
Andy
The ones I've just bought have the holes, not the dimples. The seller sent the wheel nuts as well, but two of the four locking wheel nuts are missing.
Are these replaceable individually, or do I need a new set? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #9767 21st Dec 2009 1:45am
Page 1 of 4 1234>
