Home > Technical (L322) > Gearchange / ECU Update |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 |
Can anyone advise if there were any gearbox ECU reflashes on a TD6 for slow gear changes.
13th Nov 2011 8:53pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 955 |
Do you not think that it's more likely the transmission ECU is selecting its 'cooling strategy' mode because the fluid is overheating, or are the symptoms the same when it's cold?
13th Nov 2011 9:16pm |
Hi Phil,
13th Nov 2011 9:23pm |
Yes, ‘engine warm-up’ mode uses the same shift map as ‘sport’ mode but should only be selected automatically by the transmission ECU if the transmission fluid or engine coolant temperatures are below 60 deg. C
14th Nov 2011 11:42am |
Hi Phil,
14th Nov 2011 12:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
at a tangent, but is a diy user reset of the gearbox ecu possible.. ... - .- -.
14th Nov 2011 12:17pm |
My Omiscan is supposed to do it but I cant find the function. I'm waiting for their rechnical support to advise
14th Nov 2011 12:29pm |
According to Blackbox Solutions it’s possible to reset the learned adaptions stored by the TD6 transmission ECU using their kit - but that doesn’t apply for the 4.4 V8.
14th Nov 2011 4:34pm |
Hi Phil,
14th Nov 2011 6:45pm |
Hi BigJ
14th Nov 2011 6:58pm |
