Home > Technical (L322) > random AIR SUSP INACTIVE fault light, can anyone help? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
it could be the old battery problem...
11th Nov 2011 5:32pm |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 |
iv'e had the same mate change your battery |
11th Nov 2011 5:35pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
If you use the search facility you will find this has been discussed before. People love to suggest it is the battery because this can cause various electrical glitches, but there are numerous reasons why this fault happens and personally I don't think the battery is the most likely.
11th Nov 2011 5:46pm |
Austin Member Since: 14 Apr 2011 Location: Milton Keynes Posts: 40 |
thanks for th ideas guys, and thanks for the kind offer Rich, i think you are a bit far away from me.
11th Nov 2011 5:53pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Does sound like the situation you get after disconnecting the battery. Try the lock to lock trick after starting up but before moving off. Does this clear the lights and the fault? This action resets the steering angle sensor.
12th Nov 2011 7:13am |
Gonna check out my battery tomorrow, hopefully that'll be it!! Total numbers of faults that all come on together are, air susp inactive, hdc inactive, abs light in Amber, brake light in amber, and finally the dsc light in Amber!!
12th Nov 2011 5:37pm |
the_engineer Member Since: 25 Aug 2011 Location: alexandria Posts: 42 |
how did you get on? i have the exact same fault lights active |
20th Dec 2011 3:56pm |
20th Dec 2011 4:01pm |
looked into it today, there is a place in glasgow that specialises in it |
20th Dec 2011 6:56pm |
But and it is a big BUT.....are they used to doing FFRRs? |
20th Dec 2011 7:29pm |
a question i will have to raise. They say they specialise in 4x4 wheel alignment with 14point laser alignment of all 4 wheels. |
20th Dec 2011 7:38pm |
Specialising in 4x4 doesn't mean they are FFRR competent.....be warned |
20th Dec 2011 7:49pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
21st Dec 2011 12:21pm |
will do, thanks. I think its probably likely that one of the abs sensors has been damaged when i was hammering around there doing the track rod ends |
23rd Dec 2011 12:17am |
