Home > Maintenance & Mods (L322) > Rear washer. |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Isn't working - where's the jet, I must be missing the obvious as I can't see it anywhere |
10th Nov 2011 12:26pm |
It's at the top of the wiper under the brake light , think you will have to make sure the wiper is half way through its cycle and switch the engine off so that the blade wiper arm at sitting exactly in the middle of the screen … ====================================
10th Nov 2011 2:45pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35403 |
wiki? ... - .- -.
10th Nov 2011 2:52pm |
it's not Wiki… it's just not Worki …. ====================================
10th Nov 2011 2:54pm |
woki u say? ... - .- -.
10th Nov 2011 3:14pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
The jet is on the arm spindle end.
10th Nov 2011 3:17pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Mines like yours Alan it just runs down the rear screen is that how they are supposed to operate or should I be expect more of a squirt like the fronts ? Present :2008 TDV8 HSE
10th Nov 2011 6:32pm |
Expect a squirt , something near as the fronts ... ====================================
10th Nov 2011 6:34pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3753 |
mine just gushes down the screen, and has done so since new - never squirted! |
10th Nov 2011 8:18pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I have just recently replaced the non-return valve on the rear washer. It is like new now with a healthy squirt. It was taking forever for the water to come out as it was all running back down the tubes! £2.50 from halfords, and the stealer was wanting £80+ just to investigate.. Previously..
10th Nov 2011 8:32pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6734 |
That about sums mine up! Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
10th Nov 2011 9:07pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1715 |
Hey Contraband - Would be good to get a description of what you did for others suffering the same common problem.
11th Nov 2011 8:16am |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
I'm going to be interested in a new one way valve Every time i use the washer its dry the first time, then slight success, then it gushes all unnecessary |
11th Nov 2011 8:20am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
Sounds like its a female washer jet arrangement!
11th Nov 2011 8:33am |
