Home > Maintenance & Mods (L322) > Sidestep Dilemma
Page 2 of 5 <12345>
My Dad has deployable side steps on his VSE and whilst they work well enough but if you get a puncture you must call out Land Rover assist as the side step must come off to change a wheel . It happened to him the other week when he drove over a nail in the boat yard . 2008 MY Supercharged
Post #91420 10th Nov 2011 2:31pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
As I mentioned before I found the deployable steps to be at a stupid height when down. For little legs the step up in is still not right because they fold down too low.
The fixed steps give an even 1/2 way or thereabouts step and just works better.
There was also the concern that you can't even change a wheel without removing the deployables otherwise your warranty will be void ! Apparantly they have to be removed before jacking the vehicle.
If you like gadgets then yes get them, if you want something that looks OK & practical, then go fixed Thumbs Up
Post #91426 10th Nov 2011 2:45pm
duckworthparts
Site Sponsor
Ok worked out some fitted prices for you Mick
Fixed Steps £1086inc vat
Deployable £1920inc vat
Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #91446 10th Nov 2011 4:03pm
Pity you're a 5 and a half hour drive away Dan ... Whistle ====================================
Post #91447 10th Nov 2011 4:07pm
Buy one of these and get the wife to use it.
Cheaper.
 Discovery 4 HSE
Post #91455 10th Nov 2011 4:20pm
Sidesteps sorted decided on fixed after reading about how deployable's would need to come off in event of puncture ….
Booked in for Tuesday along with full set of Mud Flaps too … Dealership price £941.35 incl vat ... Thumbs Up
Thanks for all your input Guys ... Bow down ====================================
Post #91457 10th Nov 2011 4:25pm
Rolo
piccys when done please so we can tell you how bad it looks Laughing
..................only kidding - you know I have them on mine Thumbs Up
Post #91471 10th Nov 2011 5:46pm
Laughing Laughing Thumbs Up will try and have my chrome mirrors vents and grille on as well along with chrome diesel cap cover Whistle ====================================
Post #91475 10th Nov 2011 6:06pm
Rolo
Excellent, I love my new chromed front bumper Laughing
Post #91480 10th Nov 2011 7:08pm
Laughing Laughing Laughing Thumbs Up ====================================
Post #91481 10th Nov 2011 7:09pm
Jpickie
United Kingdom 2007 Range Rover Vogue SE Supercharged Stornoway Grey
I know i am a bit late on this topic as you have already booked your RR in but incase anybody else is reading this in the future i have deployable steps on mine which so far have performed without fault and according to the previous owner did so for him also from when the vehicle was new.
The kit comes with a switch which is fitted to the front overhead console opposite to the sunroof switch, although on my search for a RR it appears that sometimes this is omitted when fitting takes place. This switch is the key to forcing the steps to stay out when the doors are closed (as long as you don't drive off) it also turns the system on or off if you want it to. I use this so i can stand on the steps to clean the roof and to give access to the jacking points to raise the vehicle if neccessary. As an extra precaution when i jack up i remove the fuse for the steps when they are out to absolutely make sure they dont retract and hit the jack which could cause a bit of a problem! It took me a long time to work out how this switch worked as there was no instructions with the car but i found they can be downloaded free from LR TOPIX site.
Post #91804 12th Nov 2011 5:21pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Jpickie
Good tips about the sidesteps. Also very happy with mine and no issues whatsoever.
I looked on Topix but could only find fitting instructions. Can you point me in the right direction for the instructions on how to use the switch?
Thanks! Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #91814 12th Nov 2011 6:33pm
Jpickie
Nomad
Sorry i should have said fitting instructions as that was what i was referring to. It does show a thumb pressing the switch for 5 seconds which is what started off my searching, however this is my knowledge of how the switch works.
If the steps are working and you want to disable them: insert the key in the dash in position 1 and hold the switch whilst turning the key to position 2, the light in the switch will flash twice to confirm the system is now off. To turn the system on repeat the procedure but the light will now flash three times to confirm the system is now on.
To force the steps to stay out regardless of the position of the doors, what LR call 'roof access and jacking mode' get in the vehicle and close the doors, insert the key in the dash and turn to position two, then hold the switch for about five seconds until the light in the switch illuminates continuously then remove the key. The steps will now stay out regardless of the position of the doors unless you drive away or lock the vehicle at which point they will return to their normal function.
This works fine with mine and i hope it does for you also. Very Happy
Post #91832 12th Nov 2011 8:50pm
Nomad
Jpickie. Many thanks! Will give it a go tomorrow.
Cheers! Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #91847 12th Nov 2011 9:51pm
Thats the Sidesteps and Mud Flaps fitted …. £890.41p incl VAT … Looks ok … Thumbs Up ====================================
Post #92471 15th Nov 2011 7:38pm
Page 2 of 5 <12345>
