Home > In Car Electronics (L322) > CD Changer jammed
tilemanvogue
England 2004 Range Rover Vogue 4.4 V8 Alveston Red
CD Changer jammed
Can anyone help with my problem. Is there a way to remove the 6 disc changer cartridge from the unit, it seems to stay put when press green eject button, just makes a whirring sound and nothing. Is there a way to remove cartridge without taking out the whole unit
Thanks Guys Discovery 3.9
Range Rover 4.6 HSE 1998
L322 Range Rover Vogue 4.4 2004
Post #91356 10th Nov 2011 9:26am
hit it with a hammer.... ... - .- -.
Post #91358 10th Nov 2011 9:27am
ok seriously ,open the cd flap, hold the eject button and hit the cartridge with a small hammer...
if this doesnt work ,remove the cd changer and take apart, theres a micro switch inside that gets stuck..
Mr. Green ... - .- -.
Post #91361 10th Nov 2011 9:42am
tilemanvogue
Thanks for reply. I will try that out and see if it helps Discovery 3.9
Post #91364 10th Nov 2011 9:44am
Failing the above mentioned , Open flap hold eject button , using a wallpaper scraper you can get , either slide inside the top of the CD changer or underneath and do a bit of jiggling about with it but not with too much force tho (scraper) …. before all the smartass replies fire in ... Whistle ====================================
Post #91365 10th Nov 2011 9:50am
tilemanvogue
Cheers Mick
I am about to pop outside and give that a try, sometimes there is some other little release button on most things, thought there might be here also. Anyway wish me luck
Thanks Discovery 3.9
Post #91366 10th Nov 2011 9:56am
tilemanvogue
Well that done it. It was stuck fast, so destroyed cartridge to get it out. Now just need new cartridge, any ideas where from Discovery 3.9
Post #91368 10th Nov 2011 10:27am
http://www.ebay.co.uk/itm/Rangerover-range...884wt_1156
Or Dan @ Duckworths , site sponsor ... Thumbs Up ====================================
Post #91372 10th Nov 2011 10:40am
tilemanvogue
Thanks again for your help Mick, much appreciated.
laurie Discovery 3.9
Post #91373 10th Nov 2011 10:44am
Thumbs Up Didn't mean for you to destroy your cartridge tho ... Embarassed Embarassed ====================================
Post #91374 10th Nov 2011 10:47am
tilemanvogue
I know. I just kept gently tweaking it out, but no luck, so got a little annoyed, thought that it was the easiest way to solve the problem. Just ordered new cartridge, thanks for the ebay link Discovery 3.9
Post #91379 10th Nov 2011 11:06am
hammer must have been to big... Very Happy ... - .- -.
Post #91393 10th Nov 2011 11:29am
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
This was great. Just had the cassette jam yesterday. For a moment I thought I was working on my Wrangler. 92% of those can be fixed with a good wack from a Manchester screwdriver.
Post #349849 28th Sep 2015 7:52pm
