Home > In Car Electronics (L322) > What is Personal Telephone Integration ?
mjdronfield
Hi,
According to the Land Rover build sheet print, my 2003 Vogue has this.
A search on the web seems to say its just wiring, and doesn't do anything without more kit, which means it's of no practical use........
Am I missing the point ?
Many thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #90921 7th Nov 2011 11:42pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I thought PTI included the bluetooth module? In any case even if it's just the wiring, to successfully strip the trim and run compatible, neat wiring then replace the trim correctly on a 7-8 year old car is a battle.
Try to search on a Bluetooth device, if you see "Land Rover" stick pin 2121 in.
YMMV good luck
Post #90924 7th Nov 2011 11:52pm
from the landrover site,
PTI stands for Personal Telephone Integration, a fully integrated hands-free mobile phone system for your car via a Bluetooth® link or cradle in the centre console  ... - .- -.
Post #90956 8th Nov 2011 10:45am
Or do you mean this ?
http://www.geekologie.com/2008/06/pervwad_...up_his.php
I'll get my coat. 2008 MY Supercharged
Post #90996 8th Nov 2011 12:56pm
mjdronfield
That was a bit more integrated than I had in mind !! Rolling with laughter
I pick the car up later this week, so I'll have a go at a bluetooth search.
Just not sure it was around in 2003.........
Many thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #91006 8th Nov 2011 1:59pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
More importantly mjdronfield
How did you obtain the build sheet? I would love one for my car.
Enjoy the FFRR experience when you pick it up.
Post #91027 8th Nov 2011 4:46pm
mjdronfield
I went to the local Land Rover dealer, and a chap in the parts department printed it off his system from the registration number.
It detailed vin, colour, delivery date, options, what warranty work etc.
That was how I found out the front driveshaft recall had not been done.
Hope this helps
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #91040 8th Nov 2011 5:33pm
dave.s
good info on the bluetooth been wondering how or even if it worked,
but went with 2121 code and sorted.
cheers dave
Post #91240 9th Nov 2011 5:16pm
mjdronfield
Well, I had a few mins with the car inbetween it having some work done and it going for a valet - should collect it Monday all being well.
Had a quick go trying to pair my phone, and not much happened.
I then noticed there was not even a telephone option on the menu of the sat nav screen, so I guess it doesn't have PTI after all.... Sad
The drivers door doesn't seem to open with the central locking anymore, so they have a bit more work to do.
CD autochanger has been replaced though, and the tunes sound good.......
Mark
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #91633 11th Nov 2011 3:35pm
EVOeng
Right chaps,
I have just returned from my local O-LR-C with the build sheet and found that I do have the 'Personal Telephone Integration' - I will see if my iPhone work tomorrow.
The sheet states 'body coloured door handles' despite mine having the grey finish like every other Range Rover I have seen.
Post #91685 11th Nov 2011 6:22pm
SteveMFr
Site Sponsor
AFAIK, bluetooth was not avail from the factory till 05. The PIT was the Siemens BitII phone in the console. The same controls work with the BMW BT modules on the pre 05's, but the BMW BT (ULF) module must be added.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #92081 14th Nov 2011 12:35pm
