Home > General > Lpg V8 at last |
The fan always comes on for a minute or so when you open a door or the boot or the bonnet |
5th Nov 2011 12:35pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
fbh should be located near the near side wheel arch..if its on your touch screen switch it on and see where the sound is coming from.. ... - .- -.
5th Nov 2011 3:09pm |
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 |
Thanks for the replies, I have tried switching it on but when I press the on button it just goes straight off again, the heater/fan does not even come on. |
5th Nov 2011 4:20pm |
i think you'll find that the outside temperature must be below 5 degrees? to have it work.. ... - .- -.
5th Nov 2011 5:35pm |
Thanks for the info 47p2 & Scarey much appreciated |
5th Nov 2011 6:35pm |
K20FTY Member Since: 15 Nov 2011 Location: Derby Posts: 13 |
I'm sure i've read somewhere that the fan you hear is an internal one to draw ambient air over the internal (cabin) temperature sensor, so that when you start up, you get a realistic response from the heater/air-con, as it's 'pre-measured' the current cabin temp. 2003 L322 Vogue SE 4.4 + LPG
15th Nov 2011 9:26pm |
sounds reasonable.. ... - .- -.
15th Nov 2011 9:36pm |
