Home > General > Picked up the FFRR, few issues |
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 |
Nice job
30th Nov 2009 9:21am |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
Is your car RHD or LHD? My car had a similar problem. I had those rubber mats and one day while cleaning, i noticed that the car was tottaly soaked beneath the mat on the driver side (LDH car, on RHD should be passenger's side). I couldn't see water dripping from anywhere (I was worried because my car had the front windscreen replaced), so, on to the shop. Turns out, one of the AC tubes was disconnected and sending the water that was supposed to go to the street into the car... Easy fix under warranty and never happened again. Try to check if its dripping from anywhere, if its not, go to the warranty. (being a 2007 you should still be covered) |
30th Nov 2009 10:07am |
inkiboo Member Since: 13 Nov 2009 Location: Aubonne Posts: 80 |
It's LHD. The water is coming from the screen area as the screen and material where the roof meets the screen is wet. I think the water is coming in by the corner of the screen. |
30th Nov 2009 10:16am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
The condensation in the rear lights is a known issue and if your car is under warranty you can have them replaced.
30th Nov 2009 11:59am |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
That's not impossible but I think a blocked sunroof drain channel is more likely. The older I get, the more I realise that people confuse wrinkles for wisdom |
30th Nov 2009 2:03pm |
Would you happen to know an official LR document number that describes the warranty fix? I am dealing with Switzerland and they are not great in English (plus the warranty runs out in Jan!) |
30th Nov 2009 3:49pm |
I can't view the details but these may be worth mentioning:
30th Nov 2009 5:46pm |
Thank you very much for that. All I need to do is try and find time for a Swiss garage to fix the problems! Next appointment is mid Jan; after the warranty runs out!
1st Dec 2009 9:26am |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Don't think they would be bothered, as the cost is paid by LR.
1st Dec 2009 12:14pm |
After the warranty runs out?????? Come on men, is this your first car? Have you bought it from a LR dealer? Your questions seem strange. When you have a problem they should fix it whatever the date. They should check your car, report the issues to LR and then fix them even if at that time you're out of warranty (The problems have been reported so it shouldn't be no longer your problem) If they're pushing you to January to ''expire'' the warranty, then something's not right Whenever I had something with my car, I called the dealer immediatly. If it was something that could wait they would put it together with the service, if not, they would take care of it. One month before my warranty expired, they told me to write down everything that needed checking so that they could receive the car before the expire date and fix everything. |
2nd Dec 2009 3:06pm |
A half decent Dealer will see warranty remedies as easy fixes and money in the bank as LR will pay for the work or they will claim it on their various and extensive insurance policies set against warranty work. Discovery 4 HSE
2nd Dec 2009 3:21pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3749 |
most motor manufacturers pay a significantly reduced labour rate to garages for undertaking warranty work. It is therefore in the garages interest to push it out of warranty and onto the customer to pay for it as they will get the full charge out rate and also the mark up % on any parts used. |
2nd Dec 2009 3:48pm |
