![]() | Home > General > What oil goes in your TD6? |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
Just had my TD6 serviced at Main Dealer in Ashford, Kent.
I have mine serviced at a main dealers and they use Shell Helix fully synthetic 5W40 . Mind you I have had it for four years and in that time the have failed to demonstrate any real stupidity . |
When the BMW engine was designed fully synthetic oil was not common place.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Even doing my last service myself i spent about £90 on the "correct" 5w 30 Magnetec, Costco do a Castrol Magnetec full synthetic but not 5w 30, its about £30 cheaper so whatever it is im using it next time. 2004 black Vogue TD6 |
From the Owners Handbook '02 model
Im looking at getting these for mine,
Well if you dont tow or do any hard work on your TD6 then the 0w30 should do, but I tow upto 2tonnes with kit in the car as well a lot so ill stick with the 5w40 me thinks |
basically then any good fully synthetic oil will do, whatever is the cheapest at the time. Can't remember what costco was doing but it was castrol full symthetic for diesels, about £28 for 4 litres.
Well i do either milage or age, so every 12months or 15k i'll do mine but need to do it soon anywy and the gearbox.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I use an old wash basin (lower in height than a bucket) |
A tip for you all. Keep an eye on the bargain web sites where the offers are mailed out to you daily. I got the heads up on an offer at Tesco on the Castrol oil for the TDV8 and it's also good for the Jag 3.0 TDV6 in Wifey's XF. Main dealers charge £12 a litre for this stuff and I got 2 litre packs at Tesco for £6.50. Needless to say I bought a stack of them, about enough to do 2 oil changes on both cars.
Seeing as fully synthetic oils are supposed to give almost zero wear and doesn't break down under heat or long use (Being "synthetic") I think it really should be the obvious choice whether towing or not?
Just had an email from the dealer.
