Home > Technical (L322) > Do I need to replace all 4 brake sensors? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35343 |
only two sensors james and only replace the one which is worn.. ... - .- -.
23rd Oct 2011 7:54pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3164 |
splendid. Many thanks. night night Stan (you do sleep at some time don't you?? ) |
23rd Oct 2011 7:56pm |
cheeky bar steward... ... - .- -.
23rd Oct 2011 7:58pm |
Fr_Raf Member Since: 20 Nov 2010 Location: Lyon - Paris Posts: 147 |
I replaced my disks and pads 2 months ago.
23rd Oct 2011 7:59pm |
only two sensors raf, one on the front near side [afaik] and one on the off side rear.. ... - .- -.
23rd Oct 2011 8:09pm |
Thank you Scarey, nothing different here. One in the front left, and the other on the rear right |
23rd Oct 2011 9:09pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Be carefull removing them as most will shatter as the plastic gets brittle with age and heat,,,
23rd Oct 2011 10:43pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
The vehicle only needs one sensor - reason being the pads are supposed to wear at the same rate in normal conditions 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
8th Nov 2011 10:41am |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Yes, works well that system, except when they don't wear at the same rate, which is what caused a three hour ride in a big yellow taxi on my way back from Scotland! Range Rover-less at the moment - Pining! |
8th Nov 2011 10:59am |
