Home > Technical (L322) > Do I need to replace all 4 brake sensors?
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Just to be safe, am just about to replace both front and rear discs and pads, having had the red warning light come on for a brake sensor alert.
Question is: Is this just one brake sensor activated or do all have to be replaced when replacing the discs/pads etc.??
Post #88638 23rd Oct 2011 7:52pm
only two sensors james and only replace the one which is worn.. ... - .- -.
Post #88639 23rd Oct 2011 7:54pm
Dolphinboy
splendid. Many thanks. night night Stan Thumbs Up (you do sleep at some time don't you?? Whistle )
Post #88640 23rd Oct 2011 7:56pm
cheeky bar steward... Laughing ... - .- -.
Post #88641 23rd Oct 2011 7:58pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
I replaced my disks and pads 2 months ago.
My first surprise was that I only have one sensor for front pads, and on for rear pads. I only have the front one dead, I can re-use the rear one as the contacts were not used.
I don't know it is normal to have only 2 sensors, but I didn't see wires on the opposites sides...
Post #88642 23rd Oct 2011 7:59pm
only two sensors raf, one on the front near side [afaik] and one on the off side rear.. ... - .- -.
Post #88643 23rd Oct 2011 8:09pm
Fr_Raf
Thank you Scarey, nothing different here. One in the front left, and the other on the rear right Bow down
Post #88656 23rd Oct 2011 9:09pm
Be carefull removing them as most will shatter as the plastic gets brittle with age and heat,,,
Craig Thumbs Up
Post #88663 23rd Oct 2011 10:43pm
Andy
The vehicle only needs one sensor - reason being the pads are supposed to wear at the same rate in normal conditions 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #90975 8th Nov 2011 10:41am
bozmandb9
Yes, works well that system, except when they don't wear at the same rate, which is what caused a three hour ride in a big yellow taxi on my way back from Scotland! Censored Range Rover-less at the moment - Pining!
Post #90986 8th Nov 2011 10:59am
