Home > Technical (L322) > Help Car wont start strange problems
44ark
2006 Range Rover Vogue SE Supercharged Zermatt Silver
Hi guys got a bit of a strange one the car is a 2006 supercharged
The wife went to use the car today and the key wouldnt turn in the ignition it eventually turned but then wouldnt start.
Also the Media screen turns on then after a certain amount of time turns off and goes black. I just went to use it and it started fine thought it might be the key fob battery and changed that as she said the central locking wouldnt work at the same time the problem occured.
So symptons are
Black Screen on Sat Nav
Key wont turn in ignition for a couple of attemps
Engine wont start
Central locking wont lock from key fob.
I have replaced the battery in the key fob and now disconnected the battery will see if this makes a difference in a bit.
The Car battery was replaced about 5 months ago but i suppose it is possible there is a battery drain any ideas guys would be great??? Supercharged LPG!!
Post #88217 20th Oct 2011 7:16pm
daveo
is your battery fully charged, sounds like its about dead... V8 facelift Range Rover Autobiography 22" wheels.
Post #88222 20th Oct 2011 8:02pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Cold weather / Duff battery Whistle
Post #88224 20th Oct 2011 8:13pm
44ark
Cheers guys are the battery's really that bad it was new 5 months ago?? Supercharged LPG!!
Post #88229 20th Oct 2011 9:08pm
daveo
you must have a drain, V8 facelift Range Rover Autobiography 22" wheels.
Post #88230 20th Oct 2011 9:15pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
FSR?
Post #88231 20th Oct 2011 9:19pm
44ark
What's fsr??? Supercharged LPG!!
Post #88277 21st Oct 2011 11:00am
Martin
Site Admin
Was it a genuine or aftermarket battery?
Post #88278 21st Oct 2011 11:04am
FSR = final stage resister..
http://www.rswsolutions.com/index.php?opti...;Itemid=78 ... - .- -.
Post #88290 21st Oct 2011 11:50am
44ark
i beleive it was an aftermarket battery but it did look like a good heavy duty one Supercharged LPG!!
Post #88320 21st Oct 2011 2:09pm
could be the battery..
my october 2010 bosch 110amp/920 crank battery is failing and is being replaced on saturday..thats only a year old.. Neutral ... - .- -.
Post #88322 21st Oct 2011 2:24pm
Googsy
5 year warranty Scarey Thumbs Up Hope you kept your receipt ... Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #88340 21st Oct 2011 4:16pm
receipt is safe and sound and battery only a year old....when i rang eurocarparts i was expecting a negative response but they said they would exchange no questions asked. ... - .- -.
Post #88351 21st Oct 2011 5:14pm
