Home > Technical (L322) > De-cat for FFRR
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
De-cat for FFRR
I've been looking into de-catting my Supercharged, it seems like a bit of a no-brainer, but in searching for a de-cat pipe for the S/C, I came across a company which offers a de-cat for the TD6.
It seems like a bit of a no-brainer, promising better consumption and more power. What is the downside ?
The company which does the de-cat are called powerspeed2008, I won't link to their site or ebay, but I'm sure anybody interested will find them.
So has anybody had it done? 2012 SDV8 Vogue SE
Post #88258 21st Oct 2011 9:22am
Does that not cause emission problems at MOT time? Got - 2017 SDV8 Autobiography in Loire Blue
Post #88259 21st Oct 2011 9:50am
Not if it has LPG, but then the new test people are banging on about will be looking for the cat unless the replacement pipe has abox in it as well...
Post #88260 21st Oct 2011 9:58am
I was speaking with an exhaust manufacturer yesterday regarding catalytic converters and he was saying everyone who has had the cat removed from their vehicle will be in trouble next MOT time as they are going to be included in the test as from next year.
He did however say that if the interior had been knocked out and the exterior was original it would be extremely difficult for the tester to prove there was no cat.
Post #88262 21st Oct 2011 10:01am
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
can this only be done on a diesel or can i do this on my 4.4 petrol/lpg
Post #88265 21st Oct 2011 10:30am
Definitely a fail from 1 1 2012 if you have no cat in place on a spark ignition engine and the car was built with one in place, spark ignition includes lpg.
No problem with compression ignition engines, take cats off if you like. Mot test as at present.
Post #88268 21st Oct 2011 10:37am
Is that right for LPG as the rules for LPG were just smoke test rules as a specific exclusion?
Post #88270 21st Oct 2011 10:39am
According to the new Inspection Test Manual it is.
There's no differentiation for lpg, all spark ignition engines are tested the same be they petrol, lpg or whatever.
I think the sales of aftermarket cats will see an increase in January. Very Happy
Post #88271 21st Oct 2011 10:46am
bozmandb9
Is it a visual check? It's pretty straightforward to ensure that there's no visible difference. 2012 SDV8 Vogue SE
Post #88272 21st Oct 2011 11:25am
Does removing the cats not increase the emission levels?
My BMW 545 just squeezed past on its last MOT and that was with the original exhaust......... Got - 2017 SDV8 Autobiography in Loire Blue
Post #88274 21st Oct 2011 11:31am
yes it doe alan but not so much with diesels.. ... - .- -.
Post #88275 21st Oct 2011 11:45am
Diesels are usually just a smoke test.
LPG used to be the same but is obviously changing now which will defintely have a big hit on a lot of people who have had them off at install time.
Post #88276 21st Oct 2011 11:48am
