Home > Technical (L322) > cooper ltz on 20" wheels?
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
couple of questions
I have managed to get myself a 2004 FFRR vogue on lpg and i love it but it is ready for tyres. It is currently running the 20" 7 spoke alloys(similar to the rangie at the top of this page) with 255 50 20 tyre but i would like to put cooper ltzs on like i had on my D3 but they arent available in this size??
Will the 275s fit with no issues,or am i better finding another set of wheels that are slightly wider?
Will RRsport wheels fit with no problems as these seem readily available and seem to suit the wider tyres better
Thanks in advance
Paul Thumbs Up
Post #87825 18th Oct 2011 7:41am
the standard wheels are 8.5j and you will have problems with wider profile tyres...RRS wheels fit ok and are 9.5j which will take wider tyres....
275/40/20 which is the normal RRS size is to small in equivalent diameter for the fullfat so you need something like 285/45/20 which is the closest and will fit the 9.5j RRS wheel.. ... - .- -.
Post #87827 18th Oct 2011 7:52am
I am no expert but I thought the 275 would fit an 8.5j Standard Wheel.....
Post #87828 18th Oct 2011 8:19am
marsie
The d3 had 275 45 20 cooper ltz fitted but i think they were a slightly wider stormer rim than on the rangie??
Post #87837 18th Oct 2011 10:12am
Trust me Zu Rims are 8.5j and the massive 275/65 18 Cooper STT's fit perfectly.......
Post #87838 18th Oct 2011 10:36am
here's a link to a rim width calculator...
http://www.alloywheels.com/tyrecalc.asp
if you put 275/40/20 into it the result is 9j to 10.5j ... - .- -.
Post #87839 18th Oct 2011 10:36am
OK it must be the 20" bit that makes the difference. Surprised
Using the calculator:
My 275/65 R18 STT's need a rim between 7.5 - 9j.....
Well done Stan Thumbs Up
Post #87840 18th Oct 2011 10:39am
marsie
think i may order some tyres up anyway. Dont particularly like the wheels i have and would prefer the sport type y spoke if they fit ok but i can swap the tyres later Thumbs Up
Paul Mr. Green
Post #87845 18th Oct 2011 11:49am
Why not make an offer on these:
http://www.ebay.co.uk/itm/4-275-55r20-COOP...500wt_1269
Great Value as priced but if offer box there you will get them cheaper......
Post #87847 18th Oct 2011 12:07pm
marsie
Saw those,trouble is they are listed as 275 55 20 profile which will mean they are quite a bit bigger radius. My old D3 had 275 45 20s???
Post #87849 18th Oct 2011 12:25pm
SteveMFr
Site Sponsor
It's not the 20", Gary, it's the aspect ratio. The taller the tire, the more you can 'bend' the sidewalls in and the narrower a rim can be. If you take Stan's 275/40 20 and change the aspect ratio to a 275/65 20 you can use a 7.5"x20" wheel.
I have the same sized tires as you on my ff. And I'm running the OEM 18" wheels which are only 7.5" wide. Great for off road as the wheel is buried in rubber and relatively well protected. On road the RR is a little loose on turn in as the tires have to fold under the wheel and settle before the car can settle into the corner.
Sorry for the thread hijack but I also thought I'd take the opportunity to show all looking at low profile tires what a proper ff looks like. :P
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #87915 19th Oct 2011 6:06am
Have you lifted your Range using Rods?
Post #87917 19th Oct 2011 6:39am
SteveMFr
Site Sponsor
No, d'you mean that seriously Gary? Shocked
It says what I did on the number plate: EASControl Razz .
http://www.fullfatrr.com/forum/topic7139.html 1st Post in the thread explains it and there is a vid showing its use.
You can also use the IIDTool as it has these functions as well (with many more comprehensive functions as well). BTW, you are the last poster in that thread.
I'm going to change my sig to 'Rods are primitive' Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #87970 19th Oct 2011 12:24pm
Sorry Steve, Not thinking straight today! (Most mornings actually....)
Post #87979 19th Oct 2011 12:54pm
marsie
If i fit range rover sport 20" Y spokes to my car will they go straight on or will i need to swap the wheel nuts aswell?
My car is a 2004 pre facelift FFRR Thumbs Up
Cheers
Post #88044 19th Oct 2011 6:56pm
