![]() | Home > In Car Electronics (L322) > Navigation on the move |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Mine just works. Haven't changed anything....? If this is a dealer-set option in the UK, presume a previous owner had it done.
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Did i not see on here somewhere that there is a 1791 code that enabled this as a cheat? I know i have seen it somewhere so will do some searching. |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
Yep, 1791 does work on MY2006 - until the beast is switched off ie not permanent. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
thanks craig.. |
TTF Member Since: 06 Feb 2012 Location: Wiltshire Posts: 130 ![]() ![]() ![]() |
OK guys; can we try some feedback in English for those of us short on technical knowledge!
should be able to do that with that tech access... |
I just got back from a long session in my car and I switched the Nav on the Move on (didn't test it yet). I did take ages to try to find TV on the move (or DVD on the move) but can not find it at all. So if someone knows where it is then I can see if I can do it with a Faultmate on a US car |
