![]() | Home > Maintenance & Mods (L322) > Rust Found - Please clean your arches today - Preventable |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
Hi,
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Whilst giving my FFRR its weekly wash this morning, I noticed a small rusty spot on my rear wheel arch lip, so I decided to take a look under the wheel arch liner to see how bad it is under there.
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
if you'd had seen where justin has been with his range then that might account for the rust.. ... - .- -.
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Corrosion warranty isn't worth the paper it's written on from my past experience with a Defender. They blamed rusting rear door, rusted bolts and headlights on 'stone chips' and as such were not available for replacement. Also, you can only have replacements if your vehicle is serviced yearly by LR themselves or an approved workshop as you have to have the 'body inspection.' |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Mine is booked in for the first week in November to get both rear arch lips treated, primed, sealed and painted before the salt arrives - they are pretty bad |
I have mine to do as well as they are getting rough looking for a 6yr old car |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
After reading this post ive cleaned my out and look ok
Just done a detailed check on my 2007 car and it's starting |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Is that rust above around the seam sealer directly above the air bag? If so, I'd be tempted to get a wire know attachment for the grinder and remove the seam sealer to make sure it isn't rotten under there. Past experiences of what lurks behind seam sealer on a couple of my mates cars is rather worrying, he's decided to totally strip the underside of his project turbo Volvo and re-coat with gravitex. It's surprising what can be hiding under all the sealer. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
S11X TT Member Since: 02 Jul 2011 Location: North East Posts: 20 ![]() ![]() |
I wire brushed all the surface rust and treated it with rust converter. It seemed to be surface rust only. The rest of the arch seemed ok. Range Rover TD6 Vogue Adriatic Blue |
If you have the wheel arch liners out lot to be said for giving the metal work a thick coating of grease or wax, won't rust then.
LR just called to say my corrosion claim has been approved, the car is now booked in to the paintshop for 5 dats startin the 5th December |
Matt@obsidian Member Since: 29 Oct 2011 Location: Greater Manchester Posts: 70 ![]() ![]() ![]() |
Just as a side note for anyone who has rust and wants to remove or control it google Bilt Hamber. They make detailing products amongst other stuff but rust control is their base. It's all water based stuff and can go down the drain. Deox gel and deox c are the products for removal and they do a couple of sprays that stop rust forming and or spreading. Comes in clear for visible areas and black for dark or concealed areas. Its self healing and will last years. I will be using it to protect exposed areas and suspension parts etc ready for winter. Their detailing clays and degreasers are the best I have used for the initiated, but avoid auto balm, it's junk Range Rover 4.4 V8 Autobiography
