Home > Off Topic > Plumbers |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Hi Guys
10th Oct 2011 4:46pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35381 |
nearly same boat as you rob, i want to knock a support wall, got quoted £1500 from one builder and £380 from another ...vast differences and both gave the same spiel ... ... - .- -.
10th Oct 2011 4:53pm |
As per 47p2 says but with 7 Radiators not 7 boilers …. |
10th Oct 2011 4:58pm |
My dad has just re-done my folks house from vented heating to central and plumbed the whole lot in, mounted the boiler then got a plumber round to tap into the gas line(he had already laid the copper pipe to each end..) and saved a good £1k by doing this.
10th Oct 2011 5:04pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
A decent sized older style house with 7 radiators would require a reasonable sized combi boiler. From my experience the boiler complete with flue is likely to cost in the order of £2000-2500 just to buy never mind install.
10th Oct 2011 5:11pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
I would also like to get shot of the old boiler thats in my house |
10th Oct 2011 5:23pm |
Brave man ….. |
10th Oct 2011 5:46pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
The cost can vary by huge amounts depending on what boiler is fitted.
10th Oct 2011 5:53pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2036 |
Wwhy copper?
10th Oct 2011 6:04pm |
No matter what system you use you still want to use copper for the main feeds then either split off smaller bore to the rads, or use a spplitter type device to knock it down a few sizes.
10th Oct 2011 6:27pm |
Yes I only meant for the smaller 10 / 5 mm pipe. Mines been in for 4 odd years now and is OK. |
10th Oct 2011 6:37pm |
But remember when you start dropping from 15mm down to 10mm and smaller the joints are still taking the same pressure . |
10th Oct 2011 6:44pm |
Cheers for the help guys. Already from your comments its clear there is a big difference in price. Got quoted £4.5-£5k which i thought was a bit steep. The boiler he mentioned was a valiant and think he said a 28jigawatt or whatever there rated in. There is only one bathroom. I would be happy to do the work myself and get it certified but think the other half would have other ideas. What would be the scrap value for my old system? Obviously they guys would factor this into there quote but could be a way of getting some money back.
10th Oct 2011 7:47pm |
Try and go for a Worcester Greenstar Highflow 440CDi @ 29.2kW or 550 CDi @ 30.6kW.
10th Oct 2011 7:59pm |
