Home > Technical (L322) > Paranoid, unlucky or just normal? |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Haven't got loads of time for a big reply as on my way to the hospital but I have a 4.4 (04) and I have the relay noise. Mine is a traditional relay click though not a buzz. I'm not worried about mine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
4th Oct 2011 3:09pm |
Cappo,
4th Oct 2011 3:22pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Probably a little unlucky, though not abnormal! Not sure about your problems, but I will say this. I was getting reduced engine performance fault codes coming up on my car, which is a 2005 Supercharged (06 MY). It was on the original Land Rover battery, though the indicator cell was black. It tested as being 'ok'. However I got it changed, and have had no faults come up since (at least not relating to the engine). If yours is the original battery, then changing it would seem to be a good place to start. Probably go for a Bosch with a 5 year warranty though, they are better than the Land Rover battery, and slightly cheaper. As you say, lovely car to drive, each one comes with a few teething problems to iron out, then the occasional gremlin to test ones commitment! Range Rover-less at the moment - Pining! |
4th Oct 2011 3:28pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
Will - it's definitely not that, it's a much heavier buzz, like a relay chattering in and out without latching and only for 0.5sec or so at a time. Fairly regular, I haven't taken a stopwatch to it but I'd say it was exactly the same time between each "buzz". |
4th Oct 2011 3:51pm |
Is it worth listening around the dash to try and hunt it down or if heavy enough touch locating it as its clicking? |
4th Oct 2011 4:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
anything in the venture cam holder or even the venture cam itself vibrating.. ... - .- -.
4th Oct 2011 4:36pm |
I'll check the cam. It is very much in that area - could even be under the little quarter panel by the passenger's left foot, but I guess without starting to remove trim, I won't know for sure. |
4th Oct 2011 5:00pm |
Well, an update to this. The buzz is definitely related to the heating system, and in some way related to my lack of fan problem.
6th Oct 2011 8:41am |
if the blowers dont work but the lights do then it could be the final stage resister... ... - .- -.
6th Oct 2011 9:20am |
Hmm, I changed that for a brand new one from a main dealer - of course there's always the possibility it was faulty from new, I guess. |
6th Oct 2011 9:24am |
Did you make sure you connected the plug on the new one properly, they can be a bit awkward |
6th Oct 2011 9:27am |
I'm 6'4" with hands like plates - but I pushed it in as far as it would go and until it clicked, so I'd hope so; or is there something else I should be checking?? |
6th Oct 2011 10:43am |
I've heard of new FSR being faulty out the box. Might be worth a try. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
6th Oct 2011 11:19am |
Did you get a final diagnosis on this as I have a client car that is buzzing for 20 seconds from the centre vents area after unlock and before the key goes in the ignition. Ideas appreciated? |
6th Mar 2014 12:10pm |
