![]() | Home > General > Suspension Query Part 2 |
I get the flashing: "AIR SUSP INACTIVE" message on the dash (no ding) and no lights from the EAS switch area (and no reaction if I try the switch). Then when I switch the ignition off I get the "ding" and the same mesage again up on the dash. That's it.
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
just a thought have you checked the sensor on the axle |
OK. Tried lock to lock turning and battery disconnect for an hour. No difference, fault remains.
If you can get underneath and disconnect the bottom connection of the sensor where it attaches to the wishbone and try moving it in both directions. Remember that the body may come down and make things a little tight under there |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Of course, if you have the "Air Susp Inactive" error it won't move until after it has been reset. |
Could be the compressor is gubbed ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
mine takes a while to get into off road...access to standard is fairly quick.. ... - .- -.
It is an airbag - Drivers Side Front. .
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1424 ![]() ![]() |
Doesn't really to be honest. Access mode is not on the bump stops ( its 20mm off the bump stops ) . Its just a lower setting of the height. So the car would still monitor the height in access mode as it would do in normal height mode. Plus, it doesnt really do much monitoring anyhow. It'll settle the vehicle once its initially parked up, and will re-adjust ( only if its needs to ) every 6 hours after that. When parked up, the only adjustments it'll make are to lower the car to the lowest wheel height. It wont start the compressor to try and lift the vehicle. Access height or normal height makes no difference to that monitoring. V8 or else ... |
