![]() | Home > General > 4 WEEKS OLD FFRR AND I DONT WANT IT ANYMORE |
See post above that stated that the reason you cannot turn the jkey is that the linkage is corroded and although selector is in Park the car is still half in gear!
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
Copper or better still iridium for LPG plugs (V expensive though)
they should run fine on normal plugs unless your engine gets hot often, ie towing work or you boot it a lot.
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
bit of an update on the car my friend has taken the car today to his garage to check out what’s going on and to service the lpg
Very common problem with the FFRR ![]() |
just hope its not shot fingers crossed he can work some magic if not can you get them cheap anywhere or cheaper |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Danny,
He thinks it could also be the 1 behind the battery as water did get in there as the run off pipe was off when I checked it so it could be either let's hope it can be sorted. Waiting on a phone call from him soon to find out my fate |
Right just had a phone call the back of the car where the nav is etc is dry no water damage all the water was behind the dash. He has taken all the control units out and sprayed them up and is taken them home tonight to dry them out he also found 14 ecu faults from bulbs miss fire suspension they are all clear now so fingers crossed the controllers will dry out and all will be good when put back together. All this was because the windscreen drain had come off so would be a good idea for everyone to check there's they are both sides under the bonnet in the rear corners don't want anyone to go through this |
LostInSpace Member Since: 28 Apr 2011 Location: Pulborough, West Sussex - ex NZ Posts: 107 ![]() ![]() ![]() |
At least the issues have been diagnosed and fingers crossed the parts dry out.
Fingers crossed. Keep us posted! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Cheers guys soon as I get any news I will keep you posted |
Update it looks like an ews ecu fault plus body sensor any idea how much to replace |
Do a search on breakerlink type website mate.
