![]() | Home > General > 4 WEEKS OLD FFRR AND I DONT WANT IT ANYMORE |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
Is the car Brand new or a car you've had for 4 weeks? 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
sorry its a 2004 90k 4.4 petrol/lpg which i bought 4 weeks ago |
No probs.
thanks ray just need some help to put this right and have some faith in it again
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
No one ever said a good marriage was easy! Lol
cheers rob
The water leak can be fixed but you need to find the source. Landrovers fix was a "water sheader". Aka a plastic bag. Have a search there is loads on it. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
wow, you seemed to have had your share of probs.as said the header tank is quite a common prob so its done and out of the way..fsr is common as well,so thats done... try disconnecting the nav and tv unit in the boot, blue and white plugs on the both units, see if this stops the staying on issue.. the lpg may need a service, did you buy it from a dealer..
bought it from a non RR dealer 3 months engine gearbox cover only no electrical |
try the nav and tv module, i bet the faults are due to water damage... V8 facelift Range Rover Autobiography 22" wheels.
have you check your spare wheel well, see if water has collected there, how about condensation, have you found it on the inside.. V8 facelift Range Rover Autobiography 22" wheels.
Get that Gear linkage on the gearbox side underneath greased ASAP (Spray Grease or WD40) |
Cheers mate what is the reason for this |
