Home > Technical (L322) > Is there a drivers door handle without a lock?
Andy
I'm getting the key re-programmed this weekend, but the dealer tells me that whoever still has my other key will be able to unlock the car manually. However, the alarm will sound and it won't start.
I was wondering if LR have ever fitted a drivers door handle without a lock? I think thats the way forward.
If so, how do you get in if the battery fails? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #8490 17th Nov 2009 10:53pm
nbunney
If the electrics fail you would have to use a brick Rolling with laughter Rolling with laughter Rolling with laughter
Post #8492 17th Nov 2009 10:57pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
couldn't you just use a rear door handle for this? I mean just the plastic cap with no hole in it.
Post #8494 18th Nov 2009 6:47am
dan_uk_1984
The passenger side has no hole - therefore I would presume that the US part for the right hand side (their passenger) would have no hole in it?
Post #8501 18th Nov 2009 12:53pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
or knowing how companies work could the be symetrical i.e can use eigher side and perhaps turn the gubbins at the back round hmmm but perhaps pop to the dealer and have a look at them in parts dept onto no6 Range Rover
Everyone needs a hobby
Post #8504 18th Nov 2009 5:40pm
Andy
just seen a Range Rover Sport whilst sat in traffic- no door locks on that one? How do they get in if the key fails then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #8577 20th Nov 2009 12:35am
adara
It's like in the Discovery 3, you pop the cap from below with the key and this clears the lock that's under it.
Post #8579 20th Nov 2009 7:13am
Andy
Well, I just called my local dealer. Supply and fit lock kit.....£890 Shocked 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #8601 20th Nov 2009 7:29pm
JW911
You can get a cheap private reg for £100 or so. The previous owner won't know which FFRR to try then. Whistle
Post #8606 20th Nov 2009 10:17pm
Andy
Having been a service engineer in the past, I'm more than capable of replacing locks - I'm not paying £900 to a dealer to do it. However, I'm guessing there's more to it than simply swapping the ignition barrel and door key. If I get a lock kit, what needs to be done in order to programme the keys etc? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #8614 21st Nov 2009 3:02pm
nbunney
Program keys, dealer only I guess
Post #8615 21st Nov 2009 3:40pm
Andy
Well - in the first instance, I've just been and bought one of these:
I've seen the fire service try and get these off with their cutting gear - they are the business!
£82 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #8616 21st Nov 2009 3:47pm
