Home > Technical (L322) > Should I be concerned? |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
How old is your battery ? onto no6 Range Rover
30th Sep 2011 9:25am |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
As above, bet your on your original battery! Range Rover-less at the moment - Pining! |
30th Sep 2011 9:28am |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
OK, I'll have a look at the date and/or get the battery tested and see what that shows - thanks! |
30th Sep 2011 9:59am |
I suppose the battery wouldn't also be a culprit for the heater issues I've also posted on?
30th Sep 2011 1:32pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35324 |
the battery is the culprit for so many failures on the range....the ecu's take so much power to operate and they seem to all 'talk' to each other and if one is not getting its full whack then the next one down the line suffers.
30th Sep 2011 2:50pm |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 |
As stan says above
30th Sep 2011 11:53pm |
