Home > Maintenance & Mods (L322) > Windscreen Buzz |
Ok I've given it a search and this noise seems to stem from the lower windscreen shroud, but mine is coming from the top of the screen right behind the rear view mirror since i gave the car and good cleaning yesterday
29th Sep 2011 1:49pm |
Check the a-pillar covers (the entire visible a-pillar is just a plastic cover). Most windshield shops stick these down when they cause probs, but the probs are usually just the clips.
29th Sep 2011 1:53pm |
Cheers Steve will give them a check when i go to pick the nipper up from school |
29th Sep 2011 1:58pm |
Ha ha, maybe i should take a video of the route i take to show its more tractor than chelsea
29th Sep 2011 8:55pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
It'll be at the bottom of the screen, my first FFRR had this problem and it was a dead simple fix, and it's a common problem, I found it with 5 minutes searching on the web.
29th Sep 2011 9:40pm |
Checked bottom scuttle and one or two of the fixing type screws seem loose but everything else around the screen seems tight
30th Sep 2011 7:07pm |
PS which post by RRVSE? |
30th Sep 2011 7:08pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
King
30th Sep 2011 7:16pm |
You mean a rubber to seal the scuttle to the bottom edge of the screen?? |
30th Sep 2011 7:23pm |
Present :2008 TDV8 HSE
1st Oct 2011 12:17am |
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 |
I had this earlier in the year really bad and annoying
1st Oct 2011 3:41pm |
