![]() | Home > Maintenance & Mods (L322) > Cat removal TD6 |
I'd say knocking its guts out should do the job but not upset any sensors from others that have done the job on the TD6.
There aren't any O2 sensors or any other sensors for that matter in a TD6 exhaust system so you can remove the guts of the pre cat and the cat without any concerns, things can only improve if you do.
I8A Jeep Member Since: 13 Apr 2011 Location: Cape Town Posts: 12 ![]() ![]() ![]() |
Thanks guys - well its out with the broom handle this weekend then... Hopefully some better performance in store once refurbished turbo back in and cats sorted - also new breather, air filter and EGR blanking. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
Good morning. From the other perspective, we have a relatively modern TD5 and we removed the cat, fitted an egr blank and chipped it. Yes the thing is now more responsive and for me thats great |
Thanks Craig. good advice. I'm not sure what the local scrappy market is like in SA for cats, but even so your idea of fitting flanged pipe sections as replaceable parts is a good one.
Graham,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
now you'll have everybody stripping their cats out and taking them to the scrappies craig.. |
Just remember that it appears that as of 1 January 2012 the MOT in the uk will require the cat to be in place at the time of mot for all cars that had them fitted at manufacture.
I believe thats why they are being stolen so offen Scarey!
funny you should say that craig, i'm sure i read somewhere that these thief's easily crawl under 4x4's and saw them off... ... - .- -.
Well, when they are worth as much as a set of stolen wheels its far less effort i guess!
Quick update as promised. New Turbo is back in, and cats removed. I must say that I dont see significant change in performance, but I was told that the turbo was over boosting before I had it repaired, so perhaps the performance gain I got from removing the cats was offset by the turbo not delivering quite so much output. In any case, I'm happy as now I dont get an awful squeel evert yime i pull away. Thanks everyone for your input. |
Thanks for the update |
