![]() | Home > My Range Rover > To LPG or not to LPG |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
I'm pretty much decided to convert my new S/C too. I'm getting around 250 miles before I fill up, which is around £100 per fill. I can get the same from £50 of LPG.
HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244 ![]() ![]() ![]() |
well I dont want to convert mine as we dont have many LPG stations over here.
So how many miles do you get on a tank of LPG CG? I assume your tank is around 92 litres, so costs around £50 to fill? I was getting 180-250 miles from a tank on my previous SC. However, I'm sure I was driving in a much more spirited manner, I think you just do when you're buying fuel at half the price, that's part of why I want to get it done, I think you can enjoy the car so much more when it costs half the money to fuel, otherwise i can see myself spending up to £300 in a week on fuel! I reckon payback for me will be within 6 months! 2012 SDV8 Vogue SE |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
What I have found is that it doesn't seem to make much difference if you drive it like Miss Daisy or whether you give it a right hard time - the mpg is fairly similar, strange but true.
I'm sure you're right! On lpg you can really push it along the motorways, and no problem, on petrol, it make such a difference if you drive at 95 instead of 70! Equally on country roads, you're punished more for overtaking on petrol! The only thing that puts me off converting it is having to be without it for up to a week! ![]() P.S. CG, I'm sure you've said before, but do you have flashlube? 2012 SDV8 Vogue SE |
[quote="bozmandb9"]
Yeah, I have Flashlube - just the basic one, not the electronic one.........I looked into it a fair bit before I converted and the general consensus was that there are a fair few SC's out there that don't have it and no probs - I decided that for the money, I'd go for the basic one - seems fine, top it up occasionally and all OK so far............fingers crossed !! My car has done 83K - I converted it at 79K - planning on keeping it for a while, I love it !!! PS Bozman - your new SC looks great !! did you put new doors on it or just repair the old ones ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
[quote="CG-SC"]
Thanks, new door skin front, new door rear, new rear wing and bumper. It looks even better in the flesh. It had some colour coding originally, gills and bonnet air intake, and now it has mirrors and door handles colour coded. On the to-do list is to extend the Piano Black trim inside, to replace the foundry finish! 2012 SDV8 Vogue SE |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
WTF!
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I don't have an LPGd SC so not my area of knowledge but don't you guys need to be careful of installation and causing faults with your engines? From what I know it's not as easy to gas as other engines? If it was easier I would consider going down this route. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
? It's booked in for tomorrow, I just really wanted some input from others on placement of the suspension compressor and fuel filler cap (since on my old car it was on the tow bar armature, which isn't present on my new car. Don't you have a 4.4? So you won't be able to copy it! @ Rob - it is easy! Hence why I'm getting it done on another car having done it six months ago! My old car is running without problem and is now owned by another forum member, Cam Tech Craig, CG SC has a converted SC too. It's just a question of getting the right kit fitted by somebody who's done them successfully before! ![]() |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6770 ![]() ![]() ![]() |
I seem to get around 270 miles/tank, have seen 300, but I was really starting to sweat!
4.4? Wash your mouth out!
CG, did you get your car LPG'd in Scotland? I would hate to get it done and not have any local support should things need work. Got - 2017 SDV8 Autobiography in Loire Blue
