![]() | Home > Technical (L322) > how to remove dashtop ? |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
The ends have to come off as well.
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
thanks for the link , i think ill leave it alone for today.I am thinking the camera is plugged into the wrong input because when i do the test it is showing to be working. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
i removed my dash last month to fit a VIM module. one thing i would say is be very carful when you are undoing the clips that secure the side air vents. the louvres are only held in place with a very small plastic stem and i snapped one of mine when i slipped with my screwdriver... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16200 ![]() ![]() ![]() |
Just a little tip, before you take the dash end covers off (wood or foundry parts) use a small flathead screwdriver and take tha airbag badges out of the A pillars and remove the torx screw. Then the A pillar covers just pull off. This will save you marking them when you put the end panels back on after refitting the dash top...
thanks for the tip |
