![]() | Home > In Car Electronics (L322) > Tow Bar Electrics |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
Just get a conversion lead, means you can tow a trailer if you ever need to. |
Just get the proper LR 13pin cable, it really isnt that much and for the faffing around it saves its well worth it |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
thanks to everyone for their hints tips and advice... |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
You need to slide part of the connector to the side to leaver the ECU off the connector. Its very tight and requires considerable force to get it to move. Hopefully it will be obvious which way to slide it, if not, post a photo of your connector and ECU and I will point out what bit to push. ![]() Gone - Range Rover Supercharged 2006 ![]() |
thanks for that justin, as i said before, i can see which way it goes, but it seems like there is a possitive stop as if something needs to be pressed maybe to help it on its way. i don't like forcing things!!
well just an update so this thread can be put to bed.
hi all, i thought this was as good a place as any to post this.
I can confirm it should go off when there is nothing behind you |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Same as you Stu, I was a little bemused by the trailer light being on all the time, on my old RRS it only came one with the indicators, but on the FFRR it is on as soon as something is plugged into the trailer sockets. Everything works it seems so I have not been worrying about it ![]() |
thanks for the replys chaps
called my local dealer today and asked about the trailer light.
