Home > Technical (L322) > Electric window not closing |
duka Member Since: 11 Jan 2011 Location: uk Posts: 145 |
Did a search but nothing reflecting my problem.
18th Sep 2011 11:15am |
Doesn't seem to reset trying the 3 second hold down - when window is fully down, press the up button, but window goes up 97% then goes back down, but only 97% down not fully into the door - any other ideas on resetting?
18th Sep 2011 3:47pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Just a refinement of advice above.
18th Sep 2011 4:01pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6722 |
Sounds like it might be the anti-trap function that senses fingers etc and drops the window again?
18th Sep 2011 4:39pm |
Sounds like the anti-trap mechanism as tried the reset many time now with no joy. Is any intervention with the anti-trap a dealer only job? Would rather look at it myself if possible?
18th Sep 2011 5:46pm |
daveym Member Since: 21 Aug 2011 Location: place Posts: 62 |
I had the same problem on the rear driverside door and after much faffing about in the end i traced it to the window switch itself. Got one from ebay for £10 and changed them over. (took 5 mins - no need to remove the door card either - youtube video shows you how.) I hope this helps. |
19th Sep 2011 5:15am |
