Home > General > Corrosion warranty disappointment
When washing the car I noticed a small blister starting on passenger side rear arch. It's only fingernail size, and early stages, but I thought if I get it now it will stop a potential spread.
I went to my local Stratstone dealer who brought in the body shop manager from Perth Stratstone.
He inspected the car, photographed it, took photocopies of my complete service history and even used a meter to check the thickness of the paint to confirm no patched damage covered up..... All was fine.
He emailed me a few days later to say sorry, but land rover had refused to repair it and there was nothing they could do.
So..... I contacted land rover h.o. To ask why. The answer I got was..
"sorry sir, but that is not corrosion, it is rust. The warranty covers corrosion but not rust"
Eh?? Anyway, they are standing fast by their decision... I am now feeling slightly cheated thinking I have spent lots of money on servicing to keep the warranties good, but when you need it, well they let you down....
(Stratstone are a good bunch, it's land rover h.o. I have the problem with.) Previously..
Post #81250 14th Sep 2011 3:17pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
http://en.wikipedia.org/wiki/Rust
"Rusting is the common term for corrosion"
But goes on to say"but the resulting oxides are not commonly called rust.
" Confused
Post #81252 14th Sep 2011 3:21pm
beat me to it rich.. Thumbs Up
Post #81253 14th Sep 2011 3:23pm
As above, rust is corroded steel.
I think you need to go back to LR and explain in words of one syllable that they are wrong.
Post #81256 14th Sep 2011 3:28pm
I can't wait to hear their interpretation of "rust"!!! Censored Got - 2017 SDV8 Autobiography in Loire Blue
Post #81258 14th Sep 2011 3:30pm
One thing you may wish to check.
Corrosion warranties usually only cover perforation due to corrosion ie corrosion from the back of the panel.
They do not cover rust on the painted surface of the panel caused by damage ie scraping etc.
Are LR saying the "rust" is on the painted surface of the panel and not due to perforation of the panel?
I think it is stretching things if they have come to this conclusion on the basis of photographs.
I think you should ask for an insurance assessor to check the "rust"
Post #81262 14th Sep 2011 3:46pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
Yes, I think unless you have a perforation (i.e a hole you can see through) they won't do anything.
Perhaps you should go back to them & ask "so will you do it once it finally perforates" ?
Post #81274 14th Sep 2011 4:42pm
ric355
I found this on their website:
Anti-corrosion warranty
Should any part of the bodywork of the vehicle be perforated by rust corrosion, the panels affected by the perforation will be repaired or replaced by any Land Rover dealer/Authorised Repairer, completely free of charge, regardless of any change in vehicle ownership.
The anti-corrosion warranty begins at the same time as the vehicle warranty and continues for a period of six years.
The term 'perforation' means a hole that penetrates through the bodywork caused by corrosion from the inside or underside as a result of faulty manufacture or materials."
Interesting they use the term 'rust corrosion' !!
Here:
http://www.landrover.com/gb/en/lr/owners/w...ssistance/
Post #81293 14th Sep 2011 6:24pm
pretlove
Bow down "RANGEISM WILL NOT BE TOLERATED"
Post #81327 14th Sep 2011 8:28pm
They are saying it is not a manufacturing fault, so it is not covered. The corrosion must start from within the metal and not on the surface they say. They are not even prepared to talk further about it.
Stratstone guy reckons about �200 to repair.... Previously..
Post #81342 14th Sep 2011 9:30pm
SharpV8
Contraband,
I've had mixed results with the corrosion warranty. Mine was processed through Croall & Bryson in Kelso. On the one hand, the upper tailgate was fixed under warranty as that was "corrosion". The wheelarch areas though were another matter: both had to be prepped, resprayed and waxoyled at my cost (about �200 I think) as it was "rust". No choice but to get it done as I couldn't just leave it to fester. In reality I think the rust prevention in some areas on these cars leaves alot to be desired - the wheel arches is just one such area. Evil or Very Mad
Always amazes me just how much better the underbody protection on the wife's Mitsubishi is vs the Range and that car cost a fraction of the price of the RR - Oh and the Colt is totally reliable too (but not too good at crossing the muddy fields) Whistle
Cheers,
SharpV8 Range Rover TDV8 Vogue SE
Post #81370 14th Sep 2011 11:24pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Re: Corrosion warranty disappointment
I feel your pain.
Obviously my FFRR is out of warranty for this, but in the past cars I've had with the warranty have taught me that it's not worth the paper it's written on.
I've never managed a successful claim on anti-corrosion warranty and with what you spend having the main dealer inspection each year and servicing it's not worth even trying to keep that warranty intact.
I'd say that if you can get it sorted by a good body shop for 2 to 3 hundred, don't put yourself through the hassle of arguing with LR about it. Chances are the body shop you choose will be better than the one LR choose and even if it's the same one, they will probably do a better job for an end customer than they would just doing the bare minimum that the warranty would pay for.
Post #81394 15th Sep 2011 10:22am
Rolo
agree with that Thumbs Up
Post #81408 15th Sep 2011 11:09am
Yip, stuff them... I'll just go private! Thanks for all your comments folks... Previously..
Post #81415 15th Sep 2011 11:42am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
To be fair, I think it's pretty reasonable that they only cover perforation, or rust from 'behind', rather than surface corrosion, since most surface corrosion can be down to the way the car is looked after.
For example 'tfr' or traffic film remover used by hand car washes is very aggressive on the lower bodywork, particularly around the wheel arches, and if the car is often used on very salty roads, without being cleaned afterwards this will make it very susceptible to corrosion, hardly Land Rover's fault.
Pretty much no manufacturer can take any different approach, especially since legislation forced them to use much less resilient water based paint! 2012 SDV8 Vogue SE
Post #81419 15th Sep 2011 12:11pm
