![]() | Home > General > Corrosion warranty disappointment |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
http://en.wikipedia.org/wiki/Rust
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
beat me to it rich.. |
As above, rust is corroded steel.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6765 ![]() ![]() ![]() |
I can't wait to hear their interpretation of "rust"!!! |
One thing you may wish to check.
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
Yes, I think unless you have a perforation (i.e a hole you can see through) they won't do anything.
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
I found this on their website:
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
They are saying it is not a manufacturing fault, so it is not covered. The corrosion must start from within the metal and not on the surface they say. They are not even prepared to talk further about it.
SharpV8 Member Since: 12 Sep 2011 Location: Northumberland Posts: 8 ![]() ![]() |
Contraband,
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I feel your pain. Obviously my FFRR is out of warranty for this, but in the past cars I've had with the warranty have taught me that it's not worth the paper it's written on. I've never managed a successful claim on anti-corrosion warranty and with what you spend having the main dealer inspection each year and servicing it's not worth even trying to keep that warranty intact. I'd say that if you can get it sorted by a good body shop for 2 to 3 hundred, don't put yourself through the hassle of arguing with LR about it. Chances are the body shop you choose will be better than the one LR choose and even if it's the same one, they will probably do a better job for an end customer than they would just doing the bare minimum that the warranty would pay for. |
agree with that ![]() |
Yip, stuff them... I'll just go private! Thanks for all your comments folks... Previously..
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1049 ![]() ![]() |
To be fair, I think it's pretty reasonable that they only cover perforation, or rust from 'behind', rather than surface corrosion, since most surface corrosion can be down to the way the car is looked after.
